R56 Can leak from water pump cause sweet smell from exhaust pipe?
Old Oct 28, 2023 | 02:53 PM
theateist's Avatar
theateist
I have Mini Cooper 2009
I noticed a sweet smell coming from the exhaust pipe. There is almost no smoke. The smell and very light smoke are noticeable in the first 2-3 minutes after ignition, but after the car warms up it is practically unnoticeable. I think the smoke is just condensation. There is no smell under the hood. I did notice the level of the coolant dropped over the past year (I only drove couple of month in total for the past year), but, the level of the coolant is still above the minimum mark.
When I replaced the brakes this week, the mechanic also took a look at the smell and said he see some leaking on the water pump (or maybe he even said the water pump was wet or something) and that gets inside the exhaust pipe. I'm also pretty sure he mentioned that the water pump is near the exhaust pipe. It was very strange to me since I know that the water pump is near the engine. So, I want to ask can the water pump somehow be the cause of the smell and is there any pump near the exhaust pipe?
Old Oct 28, 2023 | 03:48 PM
mkov608's Avatar
mkov608
Have the cooling system pressure checked.
How in the world is an exterior coolant leaking from the water pump (or near the water pump) going to get into the exhaust? The water pump is on the front right side (looking from the rear of the engine), and the exhaust manifold is on the left side of the engine. I could pressure wash the exhaust manifold and water would not get into the exhaust unless there was a hole in the manifold. I suggest you find a competent mechanic.
Old Oct 30, 2023 | 06:18 AM
RockC's Avatar
RockC
To state the obvious, signs of a leak from the coolant pump point to a bad water pump. Coolant can leak down onto the exhaust or when the car is moving air flow can cause coolant to reach the exhaust. I find it hard to imagine a scenario of leaking cooling making its way into the exhaust.
A hot cooling system pressure test is a good way to find a leak. Over the years I have found a leaking water pump, radiator, coolant tank cap, and even a plastic coolant tank.
Old Oct 30, 2023 | 06:32 PM
gauss66's Avatar
gauss66
hmmmm - as others have said - into the exhaust is pretty difficult. Dripping that finds its way onto the outside of the exhaust piping- maybe. You mention smells from the exhaust pipe - would that be tailpipe or farther upstream. Light puffs of smoke is not uncommon out of the tailpipe, especially if sitting for awhile - as it is usually condensation.
Again - start ruling things out - do a pressure check.
HCBrown
Jan 28, 2025 07:06 AM
jamesfacts
Jan 15, 2020 05:44 AM
craney
Jul 9, 2019 05:51 AM
cheetoman
Jun 7, 2019 08:55 AM
Kosmo
R55 :: Clubman Talk (2008+)
Sep 18, 2016 07:51 PM
