2006 R52 JCW new to me.
Old Oct 16, 2023 | 05:07 PM
Johnnysunrise's Avatar
Johnnysunrise
I recently bought a 2006 R52 JCW for two reasons, first it's an awesome little car and I have always wanted a MINI, and second to learn how to fix and maintain a car while not taking my everyday car off the road.
Winter is coming and the MINI is going into my garage and up on blocks for me to work on until snow melts next spring. I have plans to replace left front axle, and then work my way through all fluids and brakes.
I am learning as I go, and everything probably takes me ten times as long as it should, but the other job is to replace one of the trailing arm bushings. If I am changing one of the bushings should I try to do them all at the same time? And based on my short list, what else should I tackling at the same time?
Old Oct 16, 2023 | 10:34 PM
Fly'n Brick's Avatar
Fly'n Brick
KONI Special Active struts and a 19 or 22 MM adjustable RSB and I really like EBC redstuff brake pads. You won't believe the difference in handling.
PS: To quote an oldtimer herein: "Pictures dammit, pictures! Without pictures, it didn't happen."
Old Oct 17, 2023 | 03:38 AM
Daftlad's Avatar
Daftlad
Welcome. Would also add to your winter list: crank pulley (get an ATI), coolant expansion tank (go aluminum) and radiator fan switch. All of these are certified BMW "day ruiners."
In case you haven't discovered him yet this guy's got a pretty good channel addressing what you're after, and much, much more.
Would also get
a copy of the Bentley book a copy of the Bentley book
; bite the bullet and get the hard back, the soft back doesn't hold up over time unfortunately.
Also,
the oft-overlooked highly valuable companion book the oft-overlooked highly valuable companion book
Looking forward to your progress and pictures; good luck with the new-to-you R52!
Old Oct 17, 2023 | 05:58 AM
Johnnysunrise
Pictures
I forgot to add some pictures. Thanks for the feedback, it will help me build out the to do list for this winter and beyond. Also, I have a few videos from ModMinis qued up.
Old Oct 17, 2023 | 06:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Sounds like a fun winter project. Hopefully your garage is heated?
If replacing a bushing on one side of the car, DEFINITELY replace the other side. Doing only one side will have a negative effect the handling. Might also consider ball joints all around.
Akebono pads are a good daily driving pad.
Old Oct 17, 2023 | 10:02 AM
Fly'n Brick
Good you put the pictures up. I noticed the plastic coolant expansion tank. Replace that as well with a stainless steel one. The plastic seam will expire...usually at the most inconvenient time and place.
Old Oct 17, 2023 | 11:56 AM
Congrats from another R52 owner, does the top work and function?
Old Oct 17, 2023 | 01:10 PM
Johnnysunrise
Top works like a charm. Other than some brittle hoses and bit of wear and tear, it is hard to believe that it is a seventeen year old car.
Old Oct 17, 2023 | 03:54 PM
Fly'n Brick
The top needs periodic help. Squeaky scissor joints, I use Liquid Wrench dry lube and Raggtopp for the canvass. Also, if they are available in your area, BG products are super.
malsalah
Jul 13, 2023 06:03 AM
DFTR
Sep 20, 2022 12:30 PM
DFTR
R55 :: Clubman Talk (2008+)
Jul 7, 2021 06:56 AM
