R56 Automatic transmission questions
Old Oct 14, 2023 | 02:46 PM
Mccannro's Avatar
Mccannro
I've pulled the engine and transmission from my R56 N14 Cooper S to replace the long block. None of the manuals have the fluids info I need for the 6 speed automatic transmission.
1. Do the transmission and differential share a common fluid reservoir.
2. If not what is the fluid capacity of the differential as none of my sources separate it from the transmission.
Old Oct 15, 2023 | 04:54 AM
Vanski's Avatar
Vanski
@Mccannro ,
The differential has a different viscosity than the automatic transmission fluid. You didn't mention what year is your mini cooper what engine type you have. Here's a chart and link to provide you a better information:
1 of 3
2 of 3
3 of 3
https://www.minimania.com/MINI_Coope...lication_Guide
Hope this helps
Old Oct 15, 2023 | 08:16 AM
Mccannro's Avatar
Mccannro
It is a 2010 Copper S with the R56 N14 engine. Thanks for the charts but I do not see a differentiation between transmission and differential on the chart, unless I'm missing something.
Old Oct 16, 2023 | 02:12 AM
Vanski's Avatar
Vanski
@Mccannro ,
Ahhh...... The transfer case and differential only involves AWD. Since you have a two wheel drive, you do not have a have a transfer case and a differential(unless your mini cooper is rear wheel drive which I have never seen in a two wheel front wheel drive). Go to your local part store and ask for transmission fluid that is dedicated to mini coopers. They can provide you with a particular type of fluid.
Mccannro
Oct 16, 2023 09:14 AM
ProjectT-5R
Aug 29, 2023 09:08 PM
redwhiteR562007
Nov 19, 2022 10:35 AM
fccsswcnl
R57 :: Cabrio Talk (2009+)
Jul 14, 2013 06:46 AM
yritchey
Tires, Wheels, & Brakes
May 11, 2010 11:24 AM
