R50/53 Need help deciding 02-04 vs 05-06 R53
Old Sep 6, 2023 | 08:39 PM
kimimini's Avatar
kimimini
Need help deciding between 02-04 vs 05-06 R53. I’m a former owner of a 2009 R56 and a 2015 F56. Left the MINI scene for awhile and looking to get back in. I was set on getting a 2005-2006 R53, but can’t find much in my area. There are plenty of 2002-2004 pre facelift.
Would I regret going with 02-04 over 05-06 beside the 2 spoke steering wheel?
Any input will be much appreciated.
Old Sep 6, 2023 | 09:56 PM
Onizukachan's Avatar
Onizukachan
I went thru this a few times for myself, as well as getting asked this often by others.
In the last year I have acquired and driven routinely an early 04 PFL no frills, now a parts/donor car. a nicely optioned super early 05 FL, and a loaded 06 JCW.
benefits to FL.
Better xenon’s, pops n bangs tune, deeper gearing if you drove mostly city/stop n go, ambient lighting and puddle lights, compatible with Chrono pack, reverse is inside the taillights and works better… simpler trims around the hood that I think look nicer and less vintage-y/try hard. Door panels are different and slightly more functional, The rear view mirror is the same as later r56 and I like them better.
and I actually prefer not having the clock on the roof which screams 80s90s to me, but integrated in the tach display. The three spoke wheel is superior, the radio/controls are visible and thus more usable. The shifter is better in the FL as well. The armrest on door is usable. Radios support aux and often mp3 CD, add on Sirius, etc.
Also they tend to have better interior color options. Ie anthracite headliner, more leather options, better trim colors, better center console.
Amd of course for 06 there are factory JCW with LSD and big brakes. Also they have Teflon coated supercharger rotors like JCWs do for improved efficiency, and a better lighter crank pulley/dampener.
benefits to PFL, less expensive, more selection (they were still super kawaii/hot) more aftermarket cosmetic support) better upper motor mount (though more complex), easier to find in slicktop and the gearing is more relaxed at modern highway speeds. I don’t feel you lose much acceleration wise around town, especially with a pulley, but they sure are quieter on freeway not turning 3k plus like my FLs are. It isn’t hard to swap to 3 spoke wheel, literally about 30 minutes work start to finish. Having a separate dedicated clock can be a nice thing and the rear view mirrors are simpler. No occupancy sensor on PFL passenger seat (or super early FL like my July 2004 built 05)
downsides, you find a lot more cloth, or sensatec interiors vs leather. I’ve even seen HEATED cloth in PFL! And you can’t convert them to Chronopack as the PFL ecu doesn’t support them. the mc40 though do have extra actual functional gauges amd they have a reversed seat color scheme if that appeals to you.
I suppose my ideal one would be a FL with a LSD equipped PFL trans for better highway cruising. Which is why I’m keeping my PFL getrag from the parts car for a future change.
Hope this was of some help.
Old Sep 7, 2023 | 02:24 AM
Whisky B's Avatar
Whisky B
From what I've seen, the 05-06 Gen1's have a bit more reliability due to the discovered design flaws that came with the 02-04 models (ie. bad shifter cables, harmonic balancers, clutch release forks etc.) Granted, any R53 is going to need some work and replacement parts to get it up to spec, however imo you will likely have a few more unpleasant surprises with a pre-facelift version. Either way I'm sure there's a MINI out there somewhere that hasn't been completely neglected by its previous owner and has your name written all over it. Happy Hunting
Old Sep 7, 2023 | 11:22 AM
Boostmaster's Avatar
Boostmaster
I have both (PFL 2004 and 2006). The only things I like better about the newer one are the slick top and the side sun visor (there is no provision for one on the older car) weird how it's the little things that set them apart. Other than that they are both solid and reliable little cars.
Old Sep 7, 2023 | 12:26 PM
Daftlad's Avatar
Daftlad
Small thing but the later cars from 9/2005 onward have a non-removable fuel pump relay which is soldered inside of the fuse panel on the driver (left) side footwell. Older cars have the traditional plug-and-play relay, readily available and easy to change out for well under $10. If it goes out (like mine did recently) on a late '05 or 06 car you need to swap out the whole fuse panel.
Probably worth sourcing one well in advance of need. New ones are unobtanium of course, so you'll need to go try a salvage yard or ebay to find one.
Guess that's a 'small thing' that can turn into a 'big thing' when it goes out, but forewarned is forearmed...good luck with your decision.
Old Sep 7, 2023 | 12:39 PM
msjulie33's Avatar
msjulie33
Yikes - the part can't be desoldered and replaced?
Old Sep 7, 2023 | 12:52 PM
Daftlad's Avatar
Daftlad
Theoretically yes, requires disassembly of the board, desoldering the old one and resoldering in a new one - which you'll need to source, naturally.
Attached Thumbnails Need help deciding 02-04 vs 05-06 R53-20230428_120135.jpg
Old Sep 7, 2023 | 02:03 PM
00Mini's Avatar
00Mini
Many years ago when I was a young man I asked an older fellow who was into vintage wooden boats what was the main thing he looked for when checking out a boat and his answer was condition, condition, condition.
Old Sep 10, 2023 | 06:49 AM
kimimini's Avatar
kimimini
Thank you all for your responses. Leaning toward 05-06, but availability and conditions will dictates. I’ll wait a little and see. If no luck I will have to go with the PFL. Right now I can only find 3 PFL around me, 0 FL North East.
Grey 04 built 03 102k miles $4900 asking price
Green 04 178k miles manual $4k asking price
Blue 03 76k miles $6300 asking price.
Old Sep 10, 2023 | 07:59 AM
Boostmaster
An additional two cents- Keep hunting. There's tons of deals out there. Be prepared to travel a little. I often find these cars under $3/4k. High miles not that big a deal. Car is old. Will have worn bits and some issues. Avoid rust and electrical issues. The money you save on the purchase can go toward the inevitable refresh.
Old Sep 10, 2023 | 08:31 AM
jcolletteiii's Avatar
jcolletteiii
Best color ever pur on a MINI was put on pre-facelift cars only - Indi Blue! One thing that is a distinct positive of later cars is the driver's side sun visor. I don't care for the noisy look of the facelift headlights, so that is a neg for me, but to each their own. That facelift blue color is close though! I put a facelift ecu in my car, and let me tell you - the pops and bangs are WAY overrated. Getting it tuned soon, and those are definitely coming OUT. The pops on my stock tune were more than adequate.
Old Sep 10, 2023 | 09:50 AM
Onizukachan
And here I am trying to get more pops n bangs on both the JCW, and especially the 05 S... I was spoiled driving it with broken pre cat amd they were super awesome, and super ASBO.
Old Sep 10, 2023 | 10:29 AM
jcolletteiii
Lol! Get a borla race exhaust, the stock tune will have plenty of bangs and pops once you can hear them.
Old Sep 10, 2023 | 11:35 AM
Whisky B's Avatar
Whisky B
Yessir! I'm looking to run a Borla system after updating the rear subframe as the much needed icing on the cake. I've heard a lot of other exhausts on the R53, but the Borla... the Borla makes the MINI growl like no other.
Old Sep 10, 2023 | 01:34 PM
jcolletteiii
It does indeed! I've heard a lot of r53 exhaust systems, and nothing sounds remotely similar to the borla sport (what they used to call the "race"). Throaty not raspy, deep and dark, and no drone - can't beat it. Ironically, I have never heard the borla street exhaust sound. There was one system that was made back in the day that was pretty close actually, but that one is long gone and unavailable. Damn, I forget the name even now.
EDIT: I think it was the UUC exhaust. Can't even find a picture of it now, but it had the best tips I have ever seen for an r53 exhaust.
Old Sep 10, 2023 | 03:12 PM
Onizukachan
I’ve been looking at invidia, they seem to have that deep tone.
Old Sep 11, 2023 | 07:35 AM
cooper48's Avatar
cooper48
Recommendation: Buy one that's lived its life below the Mason/Dixon line. Rust is a huge problem on R53s in the north, especially on suspension components. Ideally, find one in Arizona/New Mexico. You'll be happier when replacing parts.
Old Sep 11, 2023 | 07:50 AM
Daftlad's Avatar
Daftlad
This, but also don't forget west coast, especially northern CA / OR / WA. Not only rust-free but paint, rubber and plastic all survive much longer the farther north you go in those states. In SoCal / southwest the sun is much more intense, and the SoCal smog while greatly dissipated since the 1970s can still wreak havoc on rubber and some plastics regardless of the number of miles on the odometer. It's a time and location thing.
Fun fact about SoCal: for the many people living in single family, single story ranch style houses with no attic or basement. Guess where all their stored junk goes? The garage, from floor to rafters, leaving the cars in the driveway to bake in the sun and take the winter deluges of rain.
Old Sep 11, 2023 | 08:52 AM
MCS4FUN's Avatar
MCS4FUN
^^^ OTOH, low mileage examples from the SW region owned and garage-kept from-new can still be found, as were both my buddy's and my R53. Patience with searching is the key. There's a 2003 R53 in Phoenix CL with 70k miles advertised by the original owner right now, claimed to have been garaged-kept since new which looks pretty good from what limited pics show.
Old Sep 11, 2023 | 12:22 PM
Onizukachan
The down side to NorCal and PNW cars is they get exposed to rain and snow.
never had a lick of rust on any bolt on any socal or AZ car I’ve ever bought, but the PW from south Texas, amd my f31 from San Fran both had some rusty bolts. Nothing like what people in the northern states see, but it was off putting for me and I had to be sure to PB Blast everything.
Old Sep 30, 2023 | 10:56 AM
kimimini's Avatar
kimimini
Thank you all! I was able to get a 2006 S with no rust. I will create a thread and share.
Boostmaster
Aug 13, 2023 06:37 AM
Mr_Stop
Sep 12, 2021 11:54 AM
yed
Southern California
May 21, 2015 01:29 PM
