F55/F56 18 F56-S roadside parking light coding
Old Aug 10, 2023 | 08:13 PM
PUNK_AND_GOTH's Avatar
PUNK_AND_GOTH
hello im trying to figure out what the coding is for roadside parking light. i see it was a standard thing in Canada but hot here in the usa .
my advisor at work ( im a technician at a mini dealer ) showed me and now i want it
Old Aug 11, 2023 | 08:10 AM
cjv2's Avatar
cjv2
Uhhh... my 2017 F56 S (US spec) does this without requiring coding.
Are you sure that when you push the lever, you're pushing it past the resistance point (like you're turning the turn signal on, not flash-to-pass)? If you don't push it past the resistance point and then hold it there as noted, you'll get no light.
If you hold it longer than the 2 seconds, that's fine too. It's not picky so long as you hold it "long enough." To turn it off, push the stalk in the other direction (like you would to deactivate an active turn signal).
Old Aug 12, 2023 | 10:43 AM
RichsMINI's Avatar
RichsMINI
Seems like a cool feature to have, tried it this morning and unfortunately it doesn’t work
Old Aug 12, 2023 | 11:02 AM
cjv2's Avatar
cjv2
Wow, this is getting interesting. What year is your F-series MINI? I'm beginning to wonder if maybe this is a pre-LCI vs LCI+ F-series thing??
Old Aug 12, 2023 | 03:43 PM
RichsMINI's Avatar
RichsMINI
2021 F56 pre-LCI2, MINI probably changed the feature/coding.
On a side note BimmerCode just had a 64MB update today when I opened the app
Old Aug 12, 2023 | 03:47 PM
cjv2's Avatar
cjv2
Cool, just got the same update. I wonder what's in it.
So I guess I'm thread fogey with the one pre-LCI example Mini so far, lol
If someone else with a 2017 or prior F55/F56 could test this out that would probably yield an answer.
Old Aug 13, 2023 | 01:27 PM
TVPostSound's Avatar
TVPostSound
Do it BEFORE you turn off the ignition.
Mine wont work after igniton off.
Old Aug 13, 2023 | 06:39 PM
cjv2's Avatar
cjv2
Interesting. Mine works after ignition off. I can walk out to the car after it has been sitting, reach in through the window, and turn the roadside parking lights on (no key on me, note I do not have Comfort Access either). In fact, if I do so, it wakes up the car (not IGN on, but similar to if I opened the door) -- and it does this whether I have the car locked or unlocked.
These variations in how it behaves are really interesting!
Old Aug 14, 2023 | 09:39 AM
RichsMINI's Avatar
RichsMINI
Tried it and no luck, oh well
Old Aug 14, 2023 | 02:28 PM
cjv2's Avatar
cjv2
Seems almost like they started fiddling with it mid-MY2017 (my 2017 is late 2016 production) and by the time you get to MY2018 it's gone... maybe
zam62
Electrical
Aug 22, 2018 05:51 AM
Braminator
Jul 25, 2012 10:34 AM
BostonR56S
Mar 31, 2009 07:02 AM
sprp85
May 5, 2006 07:15 AM
