R50/53 Harmonic Balancer and Belt Tensioner
Old Jun 9, 2023 | 06:07 PM
jjcsnlynn's Avatar
jjcsnlynn
So I had an tensioner pulley bearing making noise on the R50 so I decided to change it and the harmonic balancer since it was original from 2003.
After an adventure of a broken bolt and broken belt tool I’m done. However the new Harmon balance looks just like the old one and the balancer vibrates at idle. I’m going to try to upload a video.
is this normal? I could upload the balance but the inside the rubber strip is not uniform and looks like it’s out of balance. Outside the rubber looks good.
File Type: mov
Old Jun 9, 2023 | 06:13 PM
jjcsnlynn's Avatar
jjcsnlynn
Here is the balancer video.
File Type: mov
Old Jun 10, 2023 | 07:08 AM
cooper48's Avatar
cooper48
My initial impression is that the crank pulley is out of round. Also, I'm not a fan of lightweight pulleys because they can stress other components as is evidenced by your existing pulley movement/vibration. Fluid-filled pulleys are best. If the ATI cost is prohibitive, a PRW has the same properties. The only difference, besides cost, is the ATI is rebuildable and the PRW is not.
Old Jun 10, 2023 | 10:15 AM
jjcsnlynn's Avatar
jjcsnlynn
This an OEM pulley on the R50. Way different than my R53.
MiniMonkey08
Apr 9, 2023 11:56 AM
dayman
Nov 2, 2021 08:10 PM
philwarner
Dec 30, 2020 08:10 AM
NC TRACKRAT
Aug 15, 2009 05:15 PM
Trashman
May 9, 2008 06:36 AM
