R50/53 early vs late 2006
Old Apr 9, 2023 | 07:09 AM
meyerside's Avatar
meyerside
early vs late 2006
I looked up rear wheel hubs for my 2006 R50, and there are two options for this car, "early" and "late". How to I determine if my car is an early or a late 2006?
Old Apr 9, 2023 | 07:45 AM
Jonny's Avatar
Jonny
I know the lugs changed from 12mm to 14mm I believe sometime around July August. You should probably look up those changes first. I’m sure it coincides with the hubs.
Old Apr 9, 2023 | 09:22 AM
meyerside's Avatar
meyerside
Ah yes, found it. Thank you.
  • Notes: Rear, Wheel Bearing and Hub Assembly. Later. M14 bolts. M10 x 1.5 hub bolt. Quantity per car: 2.
  • Notes: Rear, Wheel Bearing and Hub Assembly. M12 bolts. Early. Quantity per car: 2.
Old Apr 10, 2023 | 04:16 AM
Daftlad's Avatar
Daftlad
April 2006 production date here. Believe the transition month is July/August. Recently had the LR hub bearing go bad; decided to swap all four corners to the late (M14) lug hubs; the earlier ones are becoming less plentiful.
OctaneGuy
Detailing 101
38
Jul 15, 2007 08:44 AM
RMMINICOOPER
Jan 25, 2006 11:52 AM
