R50/53 early vs late 2006
Ah yes, found it. Thank you.
- Notes: Rear, Wheel Bearing and Hub Assembly. Later. M14 bolts. M10 x 1.5 hub bolt. Quantity per car: 2.
- Notes: Rear, Wheel Bearing and Hub Assembly. M12 bolts. Early. Quantity per car: 2.
April 2006 production date here. Believe the transition month is July/August. Recently had the LR hub bearing go bad; decided to swap all four corners to the late (M14) lug hubs; the earlier ones are becoming less plentiful.
