R50/53 Removing rear lower control arm bushing
Old Mar 11, 2023 | 02:35 PM
ewgoforth's Avatar
ewgoforth
Hi,
The bushing at the back of the lower control arm on the front suspension of my 2003 R53 has gone bad. Do I need to completely remove the control arm to replace the bushing, or can I push it out of the way without completely disconnecting it except at the back?
-Eric
Old Mar 11, 2023 | 06:50 PM
deepgrey's Avatar
deepgrey
My opinion is that pulling the front subframe is the easiest way, but others may disagree.
Old Mar 12, 2023 | 03:27 AM
Daftlad's Avatar
Daftlad
Getting ready to do this job. Dreading it of course. Planning on dropping the subframe.The Mod MINI YT channel has two videos showing the two primary ways - saw/press/dig out the old one on the car, then press in the new replacement; and the second one is drop the subframe. You can't remove the LCA brackets without dropping it (thanks BMW!). Also allows access to ball joints, steering hoses, and other items of interest "while you're in there" plus clean and/or paint things.
Old Mar 12, 2023 | 07:05 AM
megaDan's Avatar
megaDan
Drop the subframe. The bushings are downright easy with the subframe out. replace everything that is questionable while you're in there. Tie rods, ball joints, etc. Enjoy many worry free more miles.
I've done it a few dozen times, feel free to message me if you have any questions. Or if you're near SE WE, drop on by
cooper48
Mar 30, 2020 03:36 PM
mad55chevy
Jul 14, 2015 08:13 PM
usman88
Suspension
Nov 14, 2007 05:11 PM
kyriian
Suspension
Aug 13, 2007 02:37 PM
