F55/F56 Are Adjustable Rear Control Arms Needed?
Old Mar 7, 2023 | 03:26 PM
Giantsfan107's Avatar
Giantsfan107
I just took my F56 to get an alignment, and was told that I need adjustable rear control arms in order to get the camber into spec. I have ST coilovers on the car. According to the spec sheet I was given, I am at -2.5 degrees of camber on the left rear, and -2.7 on the right rear. I know having the extra camber is not good for tire wear, but is there any other reason to get the adjustable control arms? If it is something I should do, I would appreciate some recommendations as to which ones to get. Thank in advance!
Old Mar 7, 2023 | 04:36 PM
TVPostSound's Avatar
TVPostSound
We have camber adjusters on the lower control arms.
Toe adjusters are near the top. Most alignment people dont know how.
Old Mar 8, 2023 | 12:13 AM
Giantsfan107
Interesting. You wouldn't happen to know how would you?
Old Mar 8, 2023 | 03:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you look at the outer control arm bolt location, you’ll see the typical alignment cam bolt:
The issue with lowering Minis is the rear suspension geometry. The rear suspension is designed to increase negative camber as it compresses. When you lower the car, the camber gain will exceed the adjustment of the OEM adjuster, and adjustable arms are needed to bring it back into spec.
Whether lowered or not, rear adjustable arms will let you dial the rear camber down. A good spec for the rear is between -1.5° to -2.0°. Make sure both sides match as close as possible.
The picture above is the NM adjustable bars. I would avoid that style with the metal ball joint on the end. They tend to be on the noisy side. Fine some that either have rubber or urethane bushings.
devenh
Suspension
Aug 22, 2014 09:17 PM
atraain
15
Sep 6, 2013 07:01 PM
eric loe
Suspension
12
Sep 28, 2010 09:46 PM
freeskier
Suspension
62
May 16, 2008 07:21 PM
Luys
Suspension
Jan 6, 2008 06:32 PM
