R56 Noise
Old Mar 6, 2023 | 04:56 AM
The Bee 61's Avatar
The Bee 61
Noise
My 2012 Cooper S is making a rubbing sound in the front right wheel well when making a slow speed, sharp right turn. Ideas?
Old Mar 6, 2023 | 05:03 AM
RockC's Avatar
RockC
Posted the following to your post on another forum (F56). Posting it here in case you didn't see it there.
Apply a bit of brake pedal while the noise is present to see if this affects it. What can happen is as the brake hardware accumulates miles a pad can drag lightly on the rotor during a turn.
Check the wheel well liner to make sure it is secure. (With another car the leading edge came loose and at speed air would force the leading edge to the pavement. But when stopped the liner would assume its correct position. Happened to notice signs of abrasion on the leading edge/under side of the liner.)
Bushing condition as offered by another thread contributor is a possibly. They'd have to pretty worn but one has to eliminate them. For this the car would have to be lifted and from under the car a tech would tug, pull, push, pry various suspension/steering members looking for signs of excessive movement/play.
Old Mar 6, 2023 | 05:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My first guess would be bearings... Put the car in neutral, jack up the front of the car, and spin the wheel by hand. It should spin pretty freely, with maybe a little bit of brake drag, if everything is good. If it feels like any resistance or extra noises in the hub area, then its the bearings.
MiniDeLux
Jan 26, 2015 11:30 AM
ClubDumpster
Jun 1, 2014 03:40 PM
TheCarMania
R60/R61 Stock Problems/Issues
Jun 13, 2012 08:36 PM
DanSeals
Jan 4, 2010 07:49 PM
Wagnbat
Nov 21, 2005 09:51 PM
