R56 Thermostat to Crossover Pipe.
Old Feb 6, 2023 | 05:40 PM
evilways570's Avatar
evilways570
I can’t seem to get my crossover pipe to sit in my thermostat properly. The water-pump side is fine and it’s clocked properly See attached.
Will this leak? If so are there any tricks?
Old Feb 7, 2023 | 06:29 PM
Drew76's Avatar
Drew76
Been 6-7 years since I did this, I did the thermostat, crossover pipe and water pump all at the same time, is everything loose and able to move a bit? Can't quite remember which side I locked in first sorry, I think that I lubed up the seals on the pipe with a little silicone grease first.
Old Feb 8, 2023 | 03:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The thermostat will not seat into the tube with the wire clip in there. The clip is installed after the thermostat is inserted to the tube.
Old Feb 8, 2023 | 05:28 AM
evilways570
I got it in. I ended up replacing the housing as well. Prior to install I marked the housing and pipe to ensure it was clocked properly. I think previously it was a bit off.
Lipofskyphoto
Apr 4, 2022 11:21 AM
JackM56
Mar 3, 2020 06:32 AM
S-2013
Mar 30, 2019 07:04 AM
RedWhiteMini
Jul 31, 2017 12:25 PM
