Drivetrain Brake Help!!!!!!
Old Jan 21, 2005 | 07:13 PM
gregsminis's Avatar
gregsminis
Brake Help!!!!!!
I am trying to swap my front pads and am getting a little, ok a lot, pissed off. I got the old pads off and now I can't fit the caliper back on with the new pads. How do I get the piston to retract enough to make it fit? I tried turning on the car and hitting the brakes then tried to push the piston back in, it would budge. Your immediate help would be appreciated. Thank you!
Old Jan 21, 2005 | 07:21 PM
Audioman's Avatar
Audioman
Clip the old pad back in the caliper and use a C-clamp to compress the piston.
Old Jan 21, 2005 | 07:26 PM
90STX's Avatar
90STX
The caliper won't go back on because the new pads are thicker, as I'm sure you've figured out. For the front brakes, you can use a c-clamp to push the piston back in a bit. Try to come up with an arrangement that pushes straight back on the piston. Before getting a specific tool to retract brake pistons, I used a c-clamp with a screwdriver perpendicular to the piston so the c-clamp would have something to push on that was centered.
If you've added any brake fluid, make sure the reservoir doesn't overflow as the piston gets pushed back in. Also, don't push the piston in further than necessary to get the caliper back on.
For the rear pistons, they will need to be turned as they are retracted. Don't just shove them straight back in like the fronts.
Good luck.
Scott
90STX
Old Jan 21, 2005 | 07:29 PM
gregsminis's Avatar
gregsminis
Thank you so much! I don't have a C-clamp but I was able to get a 4ft bar clamp to do the trick. Ahhhh (sigh of relief).
Old Jan 21, 2005 | 07:44 PM
10851CS's Avatar
10851CS
All I can say is thank God for this site and all the people on here that know a whole lot more than I do Ask a question and you get an answer
Earl
Old Jan 21, 2005 | 11:56 PM
gregsminis's Avatar
gregsminis
Earl
Isn't it great!
Old Jan 22, 2005 | 05:58 AM
petecrosby's Avatar
petecrosby
It's also a real good idea to open the bleeder valve as compress the piston. This keeps the dirty fluid, which is typically sitting in the calipers, from travelling back up into the system. That old dirty fluid can do a lot of damage to the ABS modulator. Follow up the installation of the pads with a bleeding of the brakes to flush out that old fluid.
Old Feb 7, 2005 | 09:56 PM
dafoto's Avatar
dafoto
retracting the piston on a brake change
quick and clean fix. Purchase a simple steering wheel puller from a hardware or auto supply. Leave the inner old pad on the caliper and slide the puller inside the caliper.. Tighten the bolt and force the pistion in. Takes 30 seconds and no smashed knuckles and discourteous utterances.
Old Feb 8, 2005 | 06:30 AM
onasled's Avatar
onasled
Can't do this with the rears though.
Old Feb 5, 2007 | 07:20 PM
PGT's Avatar
PGT
sorry for the thread resurrection, but, will this kit work?
Old Feb 5, 2007 | 07:25 PM
Mini Works's Avatar
Mini Works
Yes, that kit should work for both the front and the back.
victor
Old Feb 5, 2007 | 07:26 PM
PGT's Avatar
PGT
thanks Victor. Can't beat the price
Old Feb 5, 2007 | 07:44 PM
OctaneGuy's Avatar
OctaneGuy
This has been documented in my Brake Pad writeup.
https://www.northamericanmotoring.co...ight=brake+pad
As well as my Rear Pad writeup
Richard
Old Feb 6, 2007 | 04:15 AM
Audioman's Avatar
Audioman
That;s a great kit! I've had it for a couple of yearss and have used it for all my vehicles without any troubles.
And the price is right.
Old Feb 6, 2007 | 04:27 AM
norm03s's Avatar
norm03s
Patagonian GT
Where did you get that coupon?
Been wanting that kit for a while
Old Feb 6, 2007 | 04:40 AM
PGT's Avatar
PGT
I saw it linked on NASIOC, a Subaru forum. Note - only good for in-store, not online. Looks like I'll be taking a ride down to the one an hour from me.
Old Feb 6, 2007 | 04:43 AM
PGT's Avatar
PGT
Richard
perhaps sticky the threads then? I looked there first and didn't happen on the info I was looking for with a search and came upon this thread instead.
Old Feb 6, 2007 | 06:41 PM
norm03s's Avatar
norm03s
Wouldn't you know it
Tonight my brake warning light came on. I know it's the rears, thought I could make it through the Winter...darn
I think a buddy will go in on the Harbor Freight kit with me he needs to do his too
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
