Clutch slave cylinder leak
Old Jan 9, 2023 | 12:12 PM
zabond's Avatar
zabond
is there a trick [solution] to stop a leak from where the pipe [line] goes into the clutch slave cylinder
my R52 cooper S JCW has a slight drip coming from the push in connection, I even tried fitting a new slave cyl which leaked worse, is there an internal seal either in the cyl or on the pipe?
any help appreciated
Russ
Old Jan 10, 2023 | 12:55 PM
Hello,
Its the O-ring. Whats happens on install is it can pop out. Make sure the oring is installed in the unit inside the output cylinder.
https://www.realoem.com/bmw/enUS/sho...diagId=21_0178
Pipe: https://www.ecstuning.com/b-genuine-...e/21526759854/
Output cylinder: https://www.ecstuning.com/Search/Sit...h/21516777428/
Look at your end and compare to ours.
Brandon Fluharty
Jan 12, 2022 09:02 AM
edprok
Jun 8, 2016 02:51 PM
edprok
Jun 8, 2016 10:50 AM
sprint1126
Jun 23, 2013 12:40 PM
peter guldan
Aug 14, 2008 08:16 AM
