R50/53 Glovebox Organizer details
Old Dec 15, 2022 | 01:38 PM
wpgmini's Avatar
wpgmini
I have a Gen 1 Glovebox Organizer that is missing the top divider and, I am going to try and fashion one.
I possible, if any owns one of these rare species, I am looking for some details and measurements for the top divider.
A picture of the top divider would be greatly appreciated so I can see the shape.
Thanks very much.
Old Dec 15, 2022 | 02:53 PM
megaDan's Avatar
megaDan
I'll get some photos of mine tonight and will update this post. If I forget (which is likely to happen) I'll be reminded when you reply angrily that I have failed you.
Old Dec 15, 2022 | 03:02 PM
wpgmini's Avatar
wpgmini
You can count on it.
Cheers.
Old Dec 15, 2022 | 03:32 PM
Here2Go's Avatar
Here2Go
NAM Community Team
The alternative DIY
If MegaDan isn't able to reply...
I should preface by saying; I don't have an original glovebox insert/organizer.
I fabricated my own 10years ago based from an image I saw online...and I didn't add the top partition.
Since you mentioned fabricating the partition yourself and since you don't have the measurements...
Might I suggest:
#1_Place the organizer back in the glovebox
#2_Source a 12"-16" long piece of wire. Flexible (aluminum is best), enough to insert into the glovebox and top of the organizer.
#3_Form/bend and shape the wire to conform to the inside along the top shelf of the organizer, top and around to the very back
of the glovebox.
That should give you a basic rudimentary continuous outline of the piece you will need to cut/fabricate.
Notwithstanding:
Your post has given me good cause to clean out my glove box. I will probably have to repaint the inside as well.
Best of luck
Old Dec 15, 2022 | 05:12 PM
wpgmini's Avatar
wpgmini
Might I suggest:
of the glovebox.
Best of luck
Thanks for the suggestion.
I was going to use a bit of cardboard and starting from the rear, trim it to fit at the lowest position and work forwards.
Cheers.
Old Dec 15, 2022 | 06:01 PM
dmath's Avatar
dmath
@Here2Go Every time I start to feel a little bit good about what I've done to my car, you post some amazing thing you've done that makes me feel like a hack.
Old Dec 15, 2022 | 07:35 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Many of us have seen the beautiful work you've done to your MIni...
You are certainly no hack my friend!
BTW: THANK YOU
Old Dec 15, 2022 | 08:15 PM
megaDan's Avatar
megaDan
Looks like you got it figured out!
For future reference:
Old Dec 16, 2022 | 09:33 AM
Buggy's Avatar
Buggy
[QUOTE=wpgmini;4639834]I have a Gen 1 Glovebox Organizer that is missing the top divider and, I am going to try and fashion one.
Thanks very much.
Here you go! Let me know if you need more!
BTW, this was straight from the dealer and NEVER modified.
Old Dec 16, 2022 | 09:55 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Bear in mind also, it might have been "intentionally" modified at some point by someone who wanted a wider top shelf --- I don't think that it's actually necessary but I guess the partition does help from stuff sliding around...
Old Dec 16, 2022 | 10:13 AM
wpgmini's Avatar
wpgmini
Thanks very much for all your answers, pictures and measurement.
It's time to start cutting and gluing.
Much appreciated.
Cheers.
detmini13
Jul 11, 2020 07:34 PM
BRG56
Mar 15, 2020 03:12 PM
Longboard110
Mar 22, 2018 07:20 PM
wpgmini
Jul 14, 2016 12:10 PM
joshamman
May 21, 2014 12:12 AM
