Cooper S Coupe Backup Cam install
Old Dec 12, 2022 | 05:33 AM
amancuso's Avatar
amancuso
I'm installing a cam in conjunction with an ANDREAM Carplay module in my Mom's 2013 Cooper S Coupe. Everything is hooked up, however when the engine is running, the cam fails to work. I see the backup lines flicker for a few moments, then the screen goes blank. If the car is in accessory mode it works no problem. Any thoughts, ideas?
Old Dec 18, 2022 | 05:47 PM
TVPostSound's Avatar
TVPostSound
It has to do something with the bulb check.
I presume you are tapping into the reverse wires.
I cant remember the fix, search around here, someone did find a fix.
Click below.
https://www.northamericanmotoring.co...ml#post4639731
Old Dec 21, 2022 | 05:45 AM
DogfaceSGM's Avatar
DogfaceSGM
Hope that link helps. Cured my issues.
ilovepanerai
Nov 19, 2006 07:21 AM
Helix13mini
Dec 17, 2004 09:48 AM
