F55/F56 To relay or no relay?
Old Nov 9, 2022 | 03:29 PM
TVPostSound's Avatar
TVPostSound
I installed the MINI LED Rally lights. They draw under 3 amps. I presume as the supplied fuse is 3 amps!!
I'm going to wire them "old school" via a Hella switch.
Using an add-a -circuit on ignition only powered slot in the fuse box. 16 AWG wiring.
The Hella switch I chose is rated 20 amps.
Soooo, do I pass on the relay?
Relays were always intended for halogen lights drawing 20 to 30 amps.
Old Nov 9, 2022 | 05:17 PM
michaelo's Avatar
michaelo
Use an inline fuse and you should be good to go. No relay needed.
AlexQS
Mar 22, 2014 12:41 PM
slickdaddy
Mar 9, 2009 04:51 AM
ahwest
Classic Mini Talk
Jul 10, 2008 09:14 AM
MichalKub
Electrical
29
Sep 27, 2007 09:06 AM
ImagoX
Classic Mini Talk
Jul 30, 2007 10:02 AM
