R50/53 Tightening Suspension Bolts
Old Nov 5, 2022 | 05:23 AM
Rebound's Avatar
Rebound
I’ve replaced all the ball joints and bushings in the front, and all four shocks on the 2004 Cooper S.
While putting the rear shock on, the Koni had a paper that said to torque the lower bolt only with the vehicle weight on the tire. Not sure how I’ll do that, but… are there any other suspension components or bolts that need to be tightened with the vehicle on the ground and not on jack stands?
Thanks a bunch, folks!
Old Nov 5, 2022 | 05:30 AM
Mike87's Avatar
Mike87
Most of suspension pivot bolts should be tightened with the vehicle weight on them. Read, anything with rubber (or urethane or a rod end) in it.
Old Nov 5, 2022 | 06:12 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
You can use a variety of methods. Least expensive is to cut up short sections of 2x12 boards. Jack up the vehicle and put a couple under each tire. That should give you enough clearance. (Be sure to set your hand brake!) I also have a set of short Race Ramps that do nicely. Of course, you could always drive to your local service station or alignment shop and put it on their drive-on lift.
Old Nov 5, 2022 | 06:14 AM
ChiefM's Avatar
ChiefM
I used a jack stand under the control arm and then lowered the car down till it stopped moving the suspension, tightened everything and then jacked it back up, so far, no issues.
Old Nov 5, 2022 | 10:40 AM
Rebound's Avatar
Rebound
That’ll work!
What do I torque, the four ball joint center bolts? There is no bushing bolt I’m aware of, except the center subframe bolts.
Old Nov 5, 2022 | 12:02 PM
cooper48's Avatar
cooper48
Outers are 41 ft-lbs; inners are 59 ft-lbs.
Old Nov 10, 2022 | 02:06 PM
ptkacik's Avatar
ptkacik
FWIW, I tightened some suspension bolts years ago with the car in the air. Big mistake. The control arm bushing twisted and sheared and I had to replace the bushings.
Peter
Old Nov 10, 2022 | 07:41 PM
Rebound's Avatar
Rebound
Peter
Which bolts do you tighten with the car in the ground, and which with the car in the air?
Old Nov 11, 2022 | 03:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In the front, there aren’t any bolts that need to be tightened with the vehicle weight in them.
In the rear, if all you did was replace the shock, it’s just the shock mounting bolts that were removed, so no need to worry about vehicle weight when tightening either.
JAB 67
Suspension
Apr 16, 2020 05:18 PM
kingblackfoot
Jun 15, 2013 11:14 PM
blakeslee_a
Suspension
Apr 10, 2013 07:54 PM
k_h_d
Suspension
Jan 16, 2013 09:15 PM
cgaubuchon
Suspension
Apr 24, 2012 06:39 PM
