All around build r53 WTT for turbo jcw or GP
2004 Mini R53: "Mk I" Mini Cooper S
  • 2004 Mini R53: "Mk I" Mini Cooper S - All around build r53 WTT for turbo jcw or GP - Used - VIN WMWRE33464td81317 - 216,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Other - Oakcreek, WI 53154, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
Community Builder
    $14,000
    • Trade
  • Location Oakcreek, WI, 53154, USA
  • VIN WMWRE33464td81317
  • Mileage 216,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Other
Long story short befor I dump more into my car this winter , I'd like to see if I could trade it for a JCW or GP turbo , manual cooper. My car I EASILY value low end 15k BUT I'd be willing to trade down within reason for the rite car. So kbb really means nothing to me.
I will try and make this short as possible as theres so much thats been done to my r53 now since owning it. I have over 25k$ into it. Heres info :
2004 mcs with 210k miles on the body BUT prior owner befor me put in a lower mileage trans and engine and he said when he did they had around 50k.
i suspect he was truthful judging by the crosshatching still present and lack of carbon on the pistons ect when i did the head and cam. That was 5x years ago , he drove it from Cali to here and sold it to me and I've put on since owning it around 15k miles. Since starting to build it 3x years ago , the oldest mods have no more than 10k miles on them and others much much less. The car passes emissions , I with the methanol sofar pulled a best 0-60mph in 4.1sec..I have a pic of the torque app showing a 4.4 without methanol and without it estimated whp at 295..with the meth it definitely feels atleast 300whp. It's fast ! And it hooks up !
the ONLY fault light is an airbag light which is very small as I have the GPS dash option and thats where its displayed. Gps in not working . Ac as of last month has been intermittent. But other than that , there's 0 issues.. it pulls strong N hard to 8000rpm redline and build 21lb of boost..
everything pretty much has been replaced starting with eng n trans , ps system under recall by dealer , every single gasket when head n cam was done , new head bolts ect , new timing chaine ,guides and tensioner,  fuel pump and fuel filter , brake lines , ebrake cables , shifter cables, all the performance parts and what they replaced , both tmap sensors , crank , cam , coolant , both 02s , wideband , sparkplugs and oem coil ALL replaced in last 3 months or less. Indy 500 tires and rims have under 5k miles on them. I've replaced diff fluid , brake fluid ect ALL with high-performance synthetics. Sc oil is good and full. Coolant is a month old. Axles were replaced this summer also as well as a few balljoints. Like I said , the car runs n drives perfect. I'd trust it to Cali and back. I also have a slew of extra new or oem used that didn't need replacing but I still did sensors , extra 550cc injectors,  stock rims n tires , back seats , 3-4 gallons of methanol,  extra nozzles for the meth kit , spare oem sensors for pretty much the entire engine and Probably more I'm forgetting but it ALL goes with the car. Even the brand new clutchmasters lightweight aluminum flywheel.
YOU WILL NOT find another mini , with this many new parts for close to this price. If you wanna make your own by all means. Pm or respond to this post. Personal opinions arnt needed , either you love it or you hate it.
Stay safe N motor on !!!!!
here are the modifications  :
ENGINE :
. Tpr2 big valve head
. Ns1 street cam
. Gen2 Sprintex supercharger with 60mm pulley , vented fill plug and gpr billet tensioner( 23psi )
. 2% light weight crank
. Ac delete pulley
. sneedspeed Manifold with additional porting
. Obx 421 catless headers with ported flange and nvida resonated exhaust ( passes emissions)
. 550cc bosche fuel injectors
. High-flow fuel pump and new filter
. nology hotwires and ngk 1x step colder plugs
. Bmw v12 65mm throttlebody and custom 3in intake with 6in velocity stack cone filter
. grs motorsport intercooler
. Aluminum coolant and clutch fluid reservoirs
. M7 aerogel heatshield and custom intake heatshielding
. Mishimoto aluminum radiator and 180' thermostat
. Detroit tuned bypass valve
. Ported and shaved intercooler horn also tapped for the methanol
. Upgraded silicone coolant hoses and upgraded vacuum lines
. Upgraded intercooler boots
. Remote activated intercooler sprayer system ( button on steering wheel and uses rear wiper reservoir)
. Custom tuned with tuning software and laptop. 2x tuned ecu's. One for methanol one for without.
. Oil catch can
. Newer replacement Carbonfiber hydropdipped valvecover
SUSPENSION ,STEERING & BRAKES :
. R56 brake swap
. rev9 hypersteet2 coilover with caster camber plates
. drilled and slotted rotors with Ceramic pads and stainless steel flexlines and high performance dot4 brake fluid.
. brand new upper passenger side mount with polly inserts
. Front adjustable control arms
. Front and rear adjustable swaybar end links
. Rear upper and lower adjustable control arms
. Vip engine brace
. Performance lower transmission mount
. Polly filled or polly replaced stock bushings all throughout the vehicle
. Carbonfiber Front and rear strut bars
. Convertible support braces
. 16x8 lightweight rims ( 16lb) , 5mm spacers and extended lugs with 205/45 firehawk indy 500 tires with around 10k miles on them. They fill out the widebody flares well. I also have the stock rims with good tires on them..
INTERIOR AND EXTERIOR MODS :
. full bodywork and nardo Grey paintjob done in april
. Fiberglass widebody fender flares
. Coolerworx
 shifter and facelift shift cables and new transmission shift bracket and weights
. Euro parcel shelf
. Tablet running torque plus for gauging and performance monitoring and multimedia. ( wasn't installed during video)
. Rally lights running off a toggle switch
. Jcw shift light
. Custom rear seat delete, setup for under neath storage and hides injection pump and lines ( I still have the perfect condition stock rear seats ect )
. Carbonfiber steering wheel with remote activated intercooler sprayer button.
. Carbonfiber look hood vents
. Carbonfiber look side skirt/flares
. Carbonfiber side mirror covers
. Carbonfiber rear vents scoops for real cold air intake and brake master cooling
. Carbonfiber C-pillar aero panels ( installed finally, in pics with orange winter rims  )
. Carbonfiber leap v3 hoodscoop and carbonfiber air diverter
. Carbonfiber dash
. Carbonfiber hydropdipped parts that could not be purchased as real Carbonfiber.
. Carbonfiber wrapped downtubes
. Carbonfiber vinyl overlay over many other interior parts
. Carbonfiber door handle covers
. Carbonfiber gascap cover
. Carbonfiber adjustable spoiler
. Carbonfiber exterior pillars
. Carbonfiber boot lid trim
. Carbonfiber ebrake handle
. Carbonfiber look chrome delete
. aero style bumper lip
. Real custom 3d printed rear bumper vents ( with leds behind them)
. Leap rear Fiberglass diffuser
. Led Unionjack turn signal markers
. Led halo bumper running lights
. Led halo headlights and carbonfiber trims
. Led smoked sidemarkers
. Led smoked foglights
. Led smoked taillights and carbonfiber trims
. Leds in wheel wells ,front grill , hood scoop and rear bumper vents are are illuminated.
. Led color changing programable interior lighting
. Snow boost gauge / controller
. Afr gauge and wired in wideband sensor
. Fully adjustable racing seats on sliders
. Custom installed armrest
over 25k invested not including the cars purchase price...
I wont even consider ANYTHING under 15k
Old Oct 31, 2022 | 05:33 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
@ 11min I do a off the line pull upto XXX....
Old Nov 12, 2022 | 07:05 AM
MiniManAdam
Community Builder
Bump... for the few who had asked , yes. I do have a clean and clear title to the car. Never been wrecked or rebuilt ect..
if your interested , shoot me an offer...
I promise , 1x drive in this car , you'll want it !
Old Nov 27, 2022 | 03:17 AM
MiniManAdam
Community Builder
Last chance if anybody is interested.... I have a bnib clutchmasters aluminum flywheel here already
and gpr tensioner coming.. after my next purchase the car will no longer be available as it will be having the transmission built up and after that I will be wayyy too deep into this car to ever consider letting it go..
Old Dec 11, 2022 | 07:30 AM
MiniManAdam
Community Builder
Final bump and after xmas cars no longer going to be available I'm dropping the subframe and doing a bunch more mods and cleanup. I appreciate the offers sofar but when making a cash offer , anything under 12k isn't even going to be considered..
Also included is a gpr tensioner setup with new belt and removal tool AND and ac delete pulley.
Old Dec 12, 2022 | 02:05 PM
lonewolf170's Avatar
lonewolf170
Such a dope car. I'm near Schaumburg, been watching this for awhile and tempted but feel have too many cars already. 😂
Old Dec 12, 2022 | 02:59 PM
MiniManAdam
Community Builder
well , if you feel giddy , your welcome to come up and rip it around. Maybe driving it would help pursued you abit.
I have put alot of extra time into this car keeping it comfortable to drive as a daily.
little things like tightening all the interior panels and putting 2x sided tape behind spefic one or hot glue behind them so that there next to no rattles and no vibrations, , even with all aftermarket suspension amd body stiffening upgrades. It's still a comfortable pleasurable ride.. fun too.
Old Dec 12, 2022 | 04:58 PM
Dragonzsoul's Avatar
Dragonzsoul
I did a cat delete... now I need one, how much for it? xD
bump for you
Old Dec 12, 2022 | 05:47 PM
MiniManAdam
Community Builder
bump for you
12k and you get a car with it..
Old Dec 12, 2022 | 06:26 PM
Dragonzsoul
oh c'mon, i can't not say it! you set me up
that's some expensive p&ssy!
Old Dec 12, 2022 | 09:01 PM
MiniManAdam
Community Builder
lolololol
Old Dec 18, 2022 | 07:18 AM
MiniManAdam
Community Builder
I apologize to the last potential buyer but I'm going to make this VERY CLEAR , I will NOT take ANYTHING under 12,000$ for this car. I don't care if it's 11,999 ,NO....
Last guy came from middle on Missouri, like a 8hr drive 1x way.. I sent numerous videos , pics ect and he was all happy and excited, he was also 100% ok at 12k . Then he gets here , spends like 2hr looking ,driving and inspecting the car and then says " sorry but most I could get out was 10k but I'm here now and ille take it home today " I'm not interested in keeping the other set of rims and all the spare parts , everything I have that I aquired as either spares or upgrades for this car goes with it..
I didnt know to feel mad or bad but i told him , like i will tell everyone else. I , WILL , NOT , TAKE , ANYTHING , UNDER , 12K !
IF you think you can build this car for even half that , by all means be my guest..
but please PLEASE , if you , your friend or father is considering my car still , it will be 12,000$ and not 1$ less. I have absolutely no problem keeping this car , I dont need the money and i dont need to have the extra space. I LEGIT just want to move on to a new project that I can again , dive in head over heels into for a few years again.
also I do NOT drive this car on salty roads noneless in ANY weather other than nice days SO if your planning to check out the car , I HIGHLY advise checking my local weather and making sure theres been no recent snow or snow for that day... no offense but it's not fun letting someone just joyride and or feel the car out then I spend 3hr cleaning it again.
befor i owen the car it luved its life in nw cali so id like to be able to say " cars has never seen a salty road".. i take pride in having a rust free , clean car. Lol yea I know it's just a mini not a Ferrari but I take care of my things and take pride in keeping ny stuff nice.
Old Jan 20, 2023 | 04:27 PM
MiniManAdam
Community Builder
Car is no longer for sale.....
Old Aug 17, 2023 | 06:45 PM
MiniManAdam
Community Builder
Old Aug 17, 2023 | 06:47 PM
MiniManAdam
Community Builder
I've fallen for my aero so I'm now back to considering cash offers or trade for a newer turbo mini...
cmon guys , here's your chance to get the MOST mini you can per $$$ . I have a price in mind and its less than half that ive spent on parts for this car alone..
I get it it... its a labor of love.. but dont think 7k is buying the car... be realistic please..
I also have cf fenders in the mail too rite now that should be here in 2x weeks.. cf vented Hoods also down to 700$ only too ( fenders were 600)
and a nib catcam 464 to REALLY step it up.
Old Aug 22, 2023 | 08:58 AM
MiniManAdam
Community Builder
BTW, I WILL trade BOTH my r53 for a 2010 or newer S if anybody is interested getting back into some nice doneup r53's..
Old Sep 4, 2023 | 09:32 AM
PatricksR53's Avatar
PatricksR53
Fender flares
Neat car whoever gets it is gonna have a blast. Could you tell me what fender flares those are and where you got them?
Old Sep 5, 2023 | 05:06 AM
MiniManAdam
Community Builder
you'd have to check my build thread. I honestly don't remember but off hand I wannnnnnna say mini.uk , they were from over seas like alot of my parts...
I'm taking the car down too now as I've just put far too much into the car now... BUT for those who WERE interested and if you still wanna make a deal happen , I'm still open to working with you..
