R50/53 HELP! Limp mode after clutch replacement!
Old Sep 1, 2022 | 03:49 PM
kemz562's Avatar
kemz562
After I replaced the clutch, I’ve been dealing with limp mode not allowing me to go past 3k and 30mph. Accidentally broke the wheel speed sensor on the passenger side when dropping the sub frame. I soldering a used one back on, but occasionally the abs sensors and other lights will pop on. I need to do a better job soldering the wires since it intermittently comes on and sometimes makes it hard to brake. When I drove the car around the block, no CEL popped up. My question is, can a wheel speed sensor cause limp mode?
Old Sep 1, 2022 | 06:36 PM
ghostwrench's Avatar
ghostwrench
I'm pretty sure, yes.
If the car sees something abnormal like 1 wheel not at the same speed as the other 3, it will try to correct that in various ways.
Old Sep 1, 2022 | 06:51 PM
kemz562's Avatar
kemz562
Ill try tomorrow morning to try and get the sensor to read correctly. Car was running fine before changing out the clutch. Idles fine also and starts up no problem.
miniwheels
12
Nov 11, 2025 10:12 AM
Mini Wrench
Sep 26, 2020 07:46 PM
fastautoxmini
Mar 28, 2013 02:02 AM
101dals
Electrical
Apr 26, 2007 08:17 PM
CapWKidd
16
Feb 16, 2005 10:36 PM
