R50/53 Brand new clutch is SLIPPING?!!!
Old Aug 17, 2022 | 02:35 PM
Brownshoe's Avatar
Brownshoe
Pulled the trigger on a clutch job for my 2004 R50 Midlands. Took it an hour and a half away to a shop that specializes in MINIs. Had them do a bunch of other preventive maintenance "while they were in there." Ended up spending over twice the resale value of the car hoping to get a few more years out of it...
The new clutch is slipping! At 3,500 rpm in any gear, if I floor the gas pedal, it'll slip up to 4,500-5,000 rpm pretty quick.
Is this a thing that happens with new clutches? I've probably put about a thousand miles on it so far... Is there anything that can be done, or do I need to take it all the way back and make them fix it?
Old Aug 17, 2022 | 03:56 PM
Eurothrasher's Avatar
Eurothrasher
1) Did they replace the rear mail seal while in there? Any odors detected in cabin when it's slipping ?
2) Did they re-used any of the bolts for flywheel ect ? If they did, they are one time only use and have seen used ones back out.
3) 1.5hrs not a long trip when going to a shop learned in MINI, maybe call them and at least get it on record verbally until you can make the trip.
Old Aug 17, 2022 | 07:04 PM
ghostwrench's Avatar
ghostwrench
Unfortunately, I would take it back to the shop that did the work.
There is no break in for a new clutch. It should feel perfect right away.
Old Aug 18, 2022 | 05:03 AM
Minibeagle's Avatar
Minibeagle
Like others have said - take it back and get them to fix it. What you're describing is not normal.
danjreed
Sep 5, 2016 08:26 PM
hitman
Dec 20, 2011 08:45 PM
Italian_spider
Sep 21, 2011 02:03 PM
foreverfadesx
Apr 22, 2008 06:59 PM
darigaaz12
Sep 20, 2007 08:50 PM
