Error code PO100 & 102 question
Old Aug 9, 2022 | 12:45 PM
wbyberg's Avatar
wbyberg
After replacing my thermostat housing and cooling pipe today I now have a PO100 and PO102 error code for the MAF that worked just fine before the work. Check engine light is on and the triangle symbol with ! is on.
I removed and cleaned the MAF with some MAF cleaner spray and checked voltages at the 4 pin electrical connector. The OR has 13.9 v, ground (WH) is good. At idle the ohm reading on the other two wires from the MAF fluctuates between 56 & 64 but I think it is supposed to remain fairly constant.
Idle is normal but occasionally sputters. I am thinking that the MAF may be bad but seems odd it worked fine just before the work.
Any ideas?
2016 Countryman S ALL4 F60/N18 USA
70K
yusufyula
Sep 21, 2019 05:43 PM
mini907
Jun 8, 2019 06:12 PM
kramerv
Jan 29, 2018 03:29 PM
Pepper09
Dec 18, 2017 10:59 AM
inomis
Apr 9, 2014 11:54 AM
