Winter 205/40r18s? Or just swap the wheels for winter?
Old Jul 6, 2022 | 08:48 AM
ImmutableImpossible's Avatar
ImmutableImpossible
Have a bit of a conundrum on my hands:
Bought a ‘23 Cooper S with the 18” Union Jack wheels. Love them, but the tires that came with are runflat (which I appreciate and would like to keep, as this car has no doughnut spare).
The problem: I live in VT and you can’t get by without Winter-specific tires after late October. Runflats are expensive and this size/type isn’t manufactured by my go-to (Nokian Nordmans are my usual, and I love ‘em).
The question: Should I just buy the Runflats recommended by the dealership (but obv not through them), OR investigate switching for the winter? There’s not a whole lot of clearance between my tire and the wheel well, so a standard tire might not even fit. Can I reduce the wheel size and just get a smaller set of rims for winter?
thanks in advance.
Old Jul 6, 2022 | 09:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would heartily recommend getting a second set of wheels and tires for winter use. Being a Cooper S, you could probably go down to 16" wheels for winter. Tires will be MUCH less expensive in that size.
Old Jul 6, 2022 | 01:21 PM
veggivet's Avatar
veggivet
I second the opinion for a second set of winter wheels. A no brainer for Vermont, for sure!
Old Dec 1, 2022 | 08:32 AM
jimmy_racoon's Avatar
jimmy_racoon
Another vote for 2nd set of wheels for winter.
My R50 Cooper in Minnesota has a second set of matching white "holies" with mounted Blizzak WS-60's
Sure makes all the difference when the big flakes fly!
Old Dec 3, 2022 | 06:01 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The OP has a 2023 Cooper S with front brake calipers too large to fit small diameter MINI wheels like those that fit a 2005 R 50 base Cooper.
However the theory is sound and will work provided you get the right wheels. Checking with tirerack.com for a new Cooper S that comes with 18" wheels it seems they offer-
17x7" et 35 Borbet Type F wheels in black and silver painted
This will fit 205/45-17 tires which for snow could include:
Vredestein Wintrac Pro $157 each
Tirerack test result:
https://www.tirerack.com/tires/tests...y.jsp?ttid=284
Pirelli Winter Sottozero 3 $161 each
https://www.tirerack.com/tires/tests...y.jsp?ttid=181
Yokohama Bluearth Winter V905 $156 each
Old Dec 4, 2022 | 08:59 PM
dpcompt's Avatar
dpcompt
If you have an "S" hardtop, can't you fit 16" wheels. Aren't there good winter tires in 195/55 x16?
Old Dec 4, 2022 | 10:47 PM
minihune's Avatar
minihune
OK, so the first search I did on tirerack.com was for a 2023 MINI JCW and the results above were all that were offered.
Then I searched for 2023 MINI Cooper S and I now got:
12 wheels in 16x6.5 et 43-54 range
Tiresizes
185/55-16 (tire diam. 24")
Michelin X-Ice Snow tire $165 each, Perfect fit for 6" wide rim but will fit up to 6.5" wide rim OK. 87 load rated
195/55-16
Blizzak WS90 (Studless ice and snow tire) $156 each
Tirerack test result- https://www.tirerack.com/tires/tests...y.jsp?ttid=263
205/50-16
205/55-16 (tire diam. 24.8")
Michelin X-Ice Snow tire $165 each, perfect fit for 6.5" wide rim, 94 XL load rated
225/50-16
These are all possible. More narrow tire sizes may handle more snow depth.
jeffgrice
Tires, Wheels, & Brakes
Aug 5, 2010 07:14 AM
MiniMama2
Aug 25, 2008 11:53 AM
bmkiss67
DC Metro MINIs (Archive)
Jan 25, 2007 03:09 PM
72guy
Jan 9, 2007 05:42 AM
bbqbyrds
Dec 21, 2006 04:36 PM
