R56 Can’t Open door
Old Jun 2, 2022 | 11:10 AM
Justamini's Avatar
Justamini
Can’t Open door
Begging for help. Drivers door won’t open all of a sudden. Inside and outside cables are good, lock rod goes up and down when locking/unlocking. I’ve pulled the door panel and glass, been prying on the latch leveler manually and nothing, cannot get the door open at all. Is there any kind of safety release to just get the door open? I tried prying the door open but naturally the metal of the door is bending. It’s a loss here. I don’t know what else to do at this point beside literally cut the door off?
Old Jun 5, 2022 | 09:49 AM
giorgos's Avatar
giorgos
Are you refering to the decorative, visible door panel or the panel behind it (on which amongst others the window mechanism is attached to)?
I was in a similar position a couple of months ago after having removed everything but the locking mechanism from the door. In my case, the reason for the lock mechanism not releasing the door was the inadequate insertion of the interior bowden cable. The indicator on the bowden housing has to lign up with the indicator on the "socket" (see attached pictures).
modimum
Feb 20, 2011 09:21 AM
bagwell
Aug 5, 2010 07:38 PM
TimG
Jan 16, 2009 04:26 PM
PoktRokt
Dec 12, 2008 02:26 AM
