R56 Hatchback Issues
Old May 30, 2022 | 05:06 PM
AngieG's Avatar
AngieG
Hatchback Issues
It seems like the trunk cover is always a little damp. I have one of the mini heavy duty rubber covers on top of that. Does anybody else have this issue?
Old May 31, 2022 | 06:13 AM
Vanski's Avatar
Vanski
@AngieG
Do you have any lights or devices that has wires running from the outside into the inside of your car? If not, the rubber seal around the hatchback maybe worn out.
Old May 31, 2022 | 06:28 PM
PickleAhoy's Avatar
PickleAhoy
Also check the antenna seal, I had to replace the base as it had weathered away and there was evidence of a small leak on the inside of the roof liner
Old Jun 2, 2022 | 09:22 AM
Sunroof drain leak, main trunk gasket, or the seal around the antenna as the ones that leak.
Old Jun 5, 2022 | 07:43 PM
giorgos's Avatar
giorgos
After a long drive in heavy rain, there was water on the right hand side trunk for the first time. The reason was the trunk seal being just slightly loose at the top right corner of the hatch. It was still holding on tight to its frame support, just not pushed in all the way (maybe a couple or three millimeters off). Yet this allowed water to creep between the seal and the frame.
user 820283
Sep 12, 2021 01:29 PM
JHB141
Detailing 101
Feb 18, 2010 06:51 PM
andcbii
Aug 16, 2007 09:57 AM
UKCoopeR
Mar 30, 2007 08:32 PM
ToroPerro
Jan 23, 2007 09:12 PM
