R56 GFB DV+ paired with Alta spring
Old May 18, 2022 | 04:52 PM
DJ-R's Avatar
DJ-R
Has anyone tried this combo? Would it make any difference? I just ordered a gfb dv+ to replace my stock dv and was wondering if i should switch the springs also
Old May 19, 2022 | 03:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The Alta spring won’t work with the DV+
The only part you use from the OEM valve is the actuator body:
https://gfb.com.au/download/t9352-in...a0261652957728
Old May 23, 2022 | 07:32 AM
Mini242's Avatar
Mini242
Anyone have tips on working on the DV? I put the Alta spring in and it was a pain.
I have a new DV on order and dont want to spend an hour cutting my hands up like last time.
Old May 23, 2022 | 10:11 AM
DJ-R's Avatar
DJ-R
Installing/working on mine is pretty straight forward. I remove the intake pipe, move the coolant can out of the way and use a long allen wrench on the dv housing bolts. I hook the closed end of a wrench on the end of the allen wrench to loosen/tighten the dv bolts. Gives me some extra leverage
Old May 23, 2022 | 10:12 AM
DJ-R's Avatar
DJ-R
I like the little extra “pep” the gfb dv+ gives, but i sure do miss the little turbo whistle the mini had with the stock dv
Indimanic
Jul 5, 2015 09:41 AM
Indimanic
Mar 25, 2015 10:00 PM
monkiboy
R60/61 Cooper S Drivetrain
Mar 10, 2015 07:57 PM
Carey P
May 4, 2013 09:53 AM
08cooperSblack
Feb 16, 2010 10:05 PM
