R56 Valve Cover replacement
Old May 10, 2022 | 06:28 PM
JohnnyWayne's Avatar
JohnnyWayne
Having misfire issues. What is the most trusted and recomended Vavle Cover replacement out there.
Old May 11, 2022 | 03:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
How do you go from having misfires to deciding the valve cover needs to be replaced?
What is the model and year of your car?
Old May 11, 2022 | 07:18 AM
JohnnyWayne
Codes 300,302,304,1497.very rough idle and running. Plugs are clean (no oil), oil is clean (no water), no visible oil seapage around the vc. 2008 Mini S R56
Old May 11, 2022 | 07:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
P1497 is an air leak downstream of the throttle. My guess is the PCV pipe that goes from the cam cover tot he manifold is cracked. They are made from cheap plastic that cracks with age.
https://www.northamericanmotoring.co...916-p1497.html
The other codes are related to mis-fires, which could be a result of the cracked PCV hose. I would replace the hose, clear the codes, and see how she runs.
Parts diagram with part number here:
https://www.realoem.com/bmw/enUS/sho...diagId=11_3915
For purchase:
https://www.ecstuning.com/Search/Sit...h/11157605186/
Old May 11, 2022 | 11:35 AM
Bremmen Parts to the rescue!
jncunha
Apr 20, 2022 08:01 AM
scubus
Aug 30, 2021 07:58 AM
cDecker32
Aug 19, 2021 09:11 PM
bigbacon
Jan 18, 2015 10:33 AM
TheZap
Apr 1, 2014 05:59 AM
