R56 Replace relatively new Thermostat gasket?
Old Apr 4, 2022 | 07:04 AM
Lipofskyphoto's Avatar
Lipofskyphoto
Because of the relatively low cost involved, I should probably not bother to post this but ...
I need to replace my water pipe and will need to remove the thermostat to do so. I just replaced the thermostat 8/22/22.
Should I replace the gasket on the thermostat?
Old Apr 4, 2022 | 08:13 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Might not be a bad idea to have one on hand. The gaskets are pretty cheap compared to the work involved in getting to it.
https://www.ecstuning.com/Mini-2012-...mostat_gasket/
Old Apr 4, 2022 | 09:32 AM
Jason Cornelius's Avatar
Jason Cornelius
you should have just replaced that water pipe the same time you did the thermostat. I agree with Nik, you are there, might as well just replace it. I know what a PITA it is to do that job, i have replaced that stupid pipe twice in under 1 year. Buy an OEM water pipe and not a knock off, i had the Rein one, and it started leaked at the o ring into water pump after less than a year.
Old Apr 4, 2022 | 11:21 AM
Lipofskyphoto
I did replace the pipe when I replaced the thermostat.
You are right about buying a mini pipe! I bought a Burgaflex pipe from Pelican. The o ring on the thermostat side was too bog and I had a hell of a time getting it to fit.
A while after I had completed the job, the pipe began to leak again. Pelican was great about a credit for the pipe and I have a new mini pipe on hand waiting to replace the Burgaflex.
Replacing that pipe is a tough job. I see people recommending removing the intake manifold to do it, but I'll try it gain without doing that.
Tonefiend
Jun 19, 2017 05:42 PM
Striped Toad
Oct 9, 2012 04:20 PM
ultraclyde
Mar 20, 2010 08:42 AM
crichardson
Jan 3, 2010 10:38 AM
RootyK
Jun 9, 2009 02:18 PM
