R55 2010 Mini Cooper Clubman S - Coolant Issues
Old Mar 15, 2022 | 02:04 PM
RtwoDtwo1985's Avatar
RtwoDtwo1985
Been having every coolant issue conceivable with this Mini, replaced everything except for the rubber hoses at this point and now coolant is spraying from the top of the tank when it gets heated up.
Parts Replaced: Heater Core(Had a leak), Radiator(cracks from an accident), Thermostat Housing(cracked), Water Pump(leaking), Pipe between housing and water pump(Deteriorated end in the water pump), Overflow Tank and Cap.
Any ideas on what could be causing this?
Old Mar 15, 2022 | 07:18 PM
Yoshimura 1's Avatar
Yoshimura 1
Have you bled the system to get all of the air out of it......
Old Mar 15, 2022 | 09:15 PM
RtwoDtwo1985
Multiple times yes.
Old Mar 16, 2022 | 07:12 AM
Yoshimura 1
It's definitely a possibility that air is still trapped in the system
Old Mar 16, 2022 | 07:15 AM
Yoshimura 1
Leave the bleeder screw open for a while until the antifreeze starts coming out..... I let mines get to temp and then open it.
Old Mar 18, 2022 | 07:53 AM
RtwoDtwo1985
Done that a couple of times, did it again 2 days ago ran an entire tank of coolant out of it and onto the ground...no change it still overheats and shoots the fluid out of the cap.
Old Mar 18, 2022 | 08:41 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If coolant is blowing out the reservoir cap, something else is going on beside having air in the system. Are you sure you have all the hoses connected correctly in and out of the thermostat and radiator?
Old Mar 28, 2022 | 03:34 AM
HerrGruyere's Avatar
HerrGruyere
Kind of sounds like there’s a blockage.
Old Mar 28, 2022 | 06:22 AM
RtwoDtwo1985
All connections are correct, did a test, and looks like it is the head gasket...which I replaced 10,000 miles ago after the timing chain broke. About ready to run this car into the river...lol.
dildo_swaggins
Apr 7, 2019 05:32 PM
CBLJAWH
Apr 24, 2018 11:07 PM
Jhood
Sep 22, 2017 10:58 AM
wendsor
Apr 28, 2017 04:53 PM
SuperD
Aug 31, 2016 05:50 PM
