Interior/Exterior Side plastic trims
Old Jan 13, 2005 | 12:52 PM
HoyaSpook's Avatar
HoyaSpook
Side plastic trims
Hey guys
Some bozo knocked into me :(. Although the damage isn't bad, the rear driverside wheel arch (the black, plastic molding above the actual tire) broke. It is no longer flush with the chasis of the car or the rear bumper. Does anyone know where I could find this part?
Also, the rear bumper has red reflectors on each side. The driverside one was also broken. Any help?
Thanks!
Jorge
Old Jan 13, 2005 | 12:59 PM
10851CS's Avatar
10851CS
I would try the dealer unless someone has put a body kit on their MINI and has it laying around and would be willing to sell it.
Earl
Old Jan 13, 2005 | 01:02 PM
atn57's Avatar
atn57
i got one of those arces replace (rear driverside) because some teenager hit my car.........the dealer will charge you about 100 for the part, clip, and the labor.
hope it helps.
motor on
ant
Old Jan 13, 2005 | 01:06 PM
C4's Avatar
C4
Originally Posted by HoyaSpook
Hey guys
Thanks!
Jorge
Call your MINI dealer parts dept. The wheel arches are around $20-$25 each for new replacements. They are one of the cheapest pieces in the car (And they show).
The rear arches with the red side marker lights (and bulbs) are already included when you purchase a replacement plastic arch. They are very, very easy to swap. The cost of a rear side marker arch for the Cooper S is around $25 and for a regular Cooper only $10. You need to specify which model MINI you have so they give you the correct replacement plastic arch as the ones with the rear side marker lights are of different length and fit between the MCS and Cooper.
Good luck.
Old Jan 13, 2005 | 02:40 PM
HoyaSpook's Avatar
HoyaSpook
Wow
You guys are great! You made my day 10 times better! (Bad day at work, and then this).
Old Jan 13, 2005 | 02:50 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
it was only 12 bucks for the wheel trim in the back. the light is cheap also im sure. call brian at classic and he can ship you out the parts cheaper than most dealers can get you the parts! good luck.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 13, 2005 | 02:56 PM
agranger's Avatar
agranger
Yep! A guy here in the office had his son swing open the door of his other car and banged up a front wheel trim piece pretty well. The plastic took the impact well, but the clip broke. New clips and the trim piece cost him less than $20 at the dealer. I'm sure they will charge a different price for each piece, given the size and complexity of the mold. He said that it was a snap to fix.
Alwyn
Aug 26, 2015 04:53 AM
cm.d
Aug 19, 2015 08:51 AM
Mini-Hype
Aug 17, 2015 06:32 AM
