Need a source for OEM electrical connectors(DMTL)
Old Feb 16, 2022 | 05:01 PM
SD200's Avatar
SD200
My ride is a 2012 R55 and I got the check light for the DMTL pump.
I found a broken wire at the connector and managed to McGiver it back together with some solder but would like to do it right.
Does someone have a source for the OEM connectors? I need the end that plugs into the DMTL pump.
Thanks,
Old Feb 17, 2022 | 03:10 PM
SD200's Avatar
SD200
In case anyone else needs this, out motoring had a DMTL plug kit in stock.
if your wires break off like mine did right at the base this is a cheap easy fix.
KnighTT
Aug 23, 2016 03:35 PM
jbewley
Electrical
Sep 12, 2009 03:21 AM
rrigaux
Feb 29, 2004 06:58 PM
