R55 2008 Clubman S DME / ECU Failure?
Old Jan 6, 2022 | 04:00 PM
antfederici's Avatar
antfederici
Hi all! Hoping to be pointed in the right direction here...rather long story short, I purchased my 2008 Clubman S in May 2020, with 54K miles on it. Looked great, ran great, etc. Well--was I sorely mistaken. Since then I've had a cacophony of problems, one right after the other. This past August, the car completely died on me when running. I was mid acceleration and she lost all RPMs, shut off, wouldn't turn over, etc. After $6,000 in repairs I discovered I had a coolant leak, severe oil leak, a belt issue, faulty battery, the list goes on. Whoever owned the car before me had someone work on it who did not know MINI and worked on it incorrectly (wrong parts in places, missing fasteners, stripped block bastion points, etc).
After the $6K in repairs, she is back to running, BUT I'm not out of the woods. The repair shop who worked on this for me mentioned he believes my DME is fried and stuck in default mode. No temperature data is being communicated, the car never knows if it is hot or cold. When I start, there is generally a very erratic idle for about a minute. If I do not let it run for a couple of minutes before taking off, I find myself in predicaments where she will not accelerate. I'll push the pedal, RPMs will slowly creep to 3-4K before the car accelerates and shifts into gear. I get warnings that the car is running hot, even when it is not.
Has anyone experienced anything like this before? Sending my DME off to be cloned and replacing it seems rather easy...but if I'm honest, I'm apprehensive to put too much more work into this without knowing this will work. Any and all advice / help is greatly appreciated!
Thanks,
Anthony
Old Feb 24, 2022 | 10:12 PM
Clockwork's Avatar
Clockwork
Sorry, no advice here, but curious how your adventure went?
Old Feb 27, 2022 | 12:19 PM
bugeye1031's Avatar
bugeye1031
Moderator
Anthony- Hope you've resolved the car's issues. Also, I'm hoping that you can find a nearby MINI specialist that can support your car.
BillyIV
Jun 19, 2021 12:42 PM
Foody44
Feb 29, 2020 06:09 AM
stratt.c
Mar 9, 2016 03:01 PM
Seve83
R55 :: Clubman Talk (2008+)
Jul 16, 2009 02:35 PM
kyriian
197
May 2, 2008 12:23 PM
