Idling issue, R53
Old Dec 16, 2021 | 12:57 PM
cooper48's Avatar
cooper48
Idling issue, R53
Question to the forum: My '04 S has an erratic idle that varies up and down by approx. 30 RPMs. It's throwing no codes and runs just fine. Mods can be seen in my signature. Could this be a exhaust valve problem (possibly sticking)? I've owned the MINI for around 2.5 years and it has not received a walnut blast during that time. It doesn't really affect anything except my sensibilities. Anyone else run into a similar issue? Thanks.
Old Dec 16, 2021 | 01:22 PM
deepgrey's Avatar
deepgrey
I'm pretty sure my R50's idle has never been super stable, but I've never checked how much it varies. Why would you walnut blast it? It's a port injection motor.
Old Dec 16, 2021 | 01:35 PM
cooper48's Avatar
cooper48
I've never done it but my understanding is that blasting removes carbon buildup on the back of the valves and prevents them from seating properly.
Old Dec 16, 2021 | 01:40 PM
deepgrey's Avatar
deepgrey
That's typically not an issue with port injection; the gas washes the intake valves off. It's also not usually a problem on exhaust valves (well, not on the backs of the valves, at least).
Old Dec 16, 2021 | 02:48 PM
ssoliman's Avatar
ssoliman
Ac on or off?
Old Dec 16, 2021 | 03:09 PM
cooper48's Avatar
cooper48
AC off.
Old Dec 17, 2021 | 07:23 PM
ssoliman's Avatar
ssoliman
I’d say it’s normal.
are you seeing the fluctuations in inpa? The needle on tack hardly moves +- 30
Idle is a constant calculation based on readings from multiple sensors…it will naturally fluctuate
Old Dec 18, 2021 | 04:29 PM
jjcsnlynn's Avatar
jjcsnlynn
I had similar issues and tried to have the tuner smooth it out. In the end he put the idle into open loop Va closed loop and it smoothed out perfectly.
Old Dec 19, 2021 | 07:50 AM
ssoliman's Avatar
ssoliman
I’m 100% stock engine. I’ll monitor my idle and report back
Old Dec 21, 2021 | 06:07 PM
ssoliman's Avatar
ssoliman
Checked mine
was seeing 730’s -760’s…
could not hear or see the fluctuations on the tack needle
Candu61
Nov 8, 2021 08:20 AM
WhyItKeepBreakn
Mar 5, 2020 05:48 AM
CarlR53
Jun 6, 2018 06:06 AM
silence2-38554
Feb 15, 2017 08:14 AM
cabbazio311
Sep 12, 2014 06:01 AM
