2008 Mini Base Miss fire cylinder 1
Old Nov 30, 2021 | 02:14 PM
Patrick A. Peets's Avatar
Patrick A. Peets
I have a 2008 mini cooper base N12 6 speed manual that I have not been able to figure out. Mini starts fine runs great until it is at operating temp then starts miss firing on cylinder one.
Code reader just tells me miss fire cylinder one nothing more. It is as if the power has been cut off the that coil. I have ran it in sport mode with same issue.
Compression test good hot or cold. Number 1 spark plug fuel soaked. No smoke out the tailpipe.
Things I have done:
New coils
New plugs
New injector
New thermostat housing
New vanos
Checked connections
I was going to change the engine wiring harness as I have 5 coopers in my shop and have plenty of parts.
I am not a workshop for mini's I just have sickness for these little cars.
Old Dec 14, 2021 | 01:03 AM
nolimit's Avatar
nolimit
DO a compression check on all the cylinders, to start.
I had same issue with my 05, after doing compression check found my problem cylinder was low, From there I had a leak down test and that
Lead to finding a cracked exhaust valve, After rebuilt head ant the cost of about 3k total all is good. I do hope that this is not where you will end up.
By the way the cause of the cracked valve was using non Top Tier gas, so i ended up having carbon build up that caused to valve to not properly seat.
Cheers
Old Dec 17, 2021 | 09:09 AM
garry sharp's Avatar
garry sharp
post some pics
jctrue
Sep 3, 2021 10:21 PM
Jordan Smythe
Jun 11, 2021 12:32 PM
MiniMeToo
Oct 12, 2019 06:26 AM
thevastdifference
Jun 19, 2018 01:15 PM
MiniLes
Dec 6, 2015 11:07 PM
