Electrical Fault? Crank no start with 28BD & 27B4
Old Nov 15, 2021 | 08:26 AM
DurrtySteve's Avatar
DurrtySteve
I took my intake manifold off and walnut blasted my intake ports on my R55. After putting everything back together my car will not start. Checking the codes I get a 28BD (throttle valve closing spring check) and 27B4 (tank venting valve activation). I think the throttle isn't opening so I'm not getting ignition. I replaced the throttle body with a new one but it did not help. Since the throttle body and tank venting valve are wired to the same harness, I figure it's an electrical issue. The wiring itself appears to be in good physical condition. I've never had trouble starting the car before walnut blasting. I've read online it could be as simple as a grounding issue? Could someone please point me to where I should start?
Old Feb 12, 2023 | 12:34 PM
SebR56's Avatar
SebR56
Update?
did you get to figure this out?
BiannualPoet
Jun 6, 2021 03:40 PM
thadscottmoore
Jun 4, 2021 07:19 AM
Justin Nemec
Feb 25, 2016 12:43 PM
willy-mini
May 7, 2015 10:35 AM
SFarbolin
Dec 7, 2014 09:52 PM
