Found a Roller in my Oil Pan
Old Nov 10, 2021 | 01:33 PM
stp's Avatar
stp
Pulled my oil pan as part of a partial rebuild of my R56 N14 2009 Cooper S. No metal shavings or metal particles other than this roller. Anybody have a clue where this came from? I expected to find (and did) plastic pieces of the timing chain tensioner/guide because it's messed up but not this...
Old Nov 13, 2021 | 08:34 PM
Mnkytweet's Avatar
Mnkytweet
At first, I was thinking it could be some sort of bushing. A hell of a lot of the hardware holes in the have similar bushings. I think that its a little too thick-walled for that. Maybe a guide pin?
Old Nov 14, 2021 | 10:38 AM
stp's Avatar
stp
Still not sure exactly. Cylinder Head still in the shop, maybe the Head guy will know....
Old Nov 14, 2021 | 12:01 PM
oldbrokenwind's Avatar
oldbrokenwind
The tapered ends make me believe it's a guide pin, but the hole looks pretty small.Some, but not all guide pins have holes, i.e., one for mounting the starter. And the wear pattern looks like it was a "roller" of some kind, and the hole is where the "axle" was. What's the largest diameter metric bolt that will fit?
Have you checked the RealOEM parts lists --- https://www.realoem.com/bmw/enUS/select ? Both cylinder head and engine block have parts similar to your unknown.
Old Nov 15, 2021 | 08:35 AM
Gubi's Avatar
Gubi
Looks kinda like the pin on the rocker arm roller, but that may not have the hole in the center.
NB Cooper
Nov 28, 2020 04:39 AM
Corey Oppenheimer Credeur
Sep 7, 2020 06:58 PM
dcrohan
Feb 24, 2017 04:33 AM
weaver9000
Sep 14, 2015 05:48 PM
Mabbottusmc
Mar 8, 2011 04:31 AM
