R55 Bad "new" Waterpipe
Old Oct 7, 2021 | 02:07 PM
laurel51's Avatar
laurel51
Bad "new" Waterpipe
Just finished replacing the head on my non-turbo '09 Clubman, while in there I did a new water-pump & the pipe between the pump and t-stat. When refilling the water it all came out the bottom. Upon inspection I found the joint between the stat & pipe to be the leak! After looking it over I found a large lump right in the "O" ring seat on the t-stat end. On the outside of the pipe opposite the "lump"is a circle which looks like it may be where a nozzle injected the plastic to make the part!
So, this is a warning to look over any water pipes you may be buying for your Mini's, this was bought from a well respected dealer I see on may forums, listed as a good place to buy!
Old Oct 10, 2021 | 09:57 PM
scott13's Avatar
scott13
Thanks for the warning, I have seen many posts on NAM recommending only OEM for this part. Lots of work only to see the part fail.
Old Oct 11, 2021 | 04:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Did you use an OEM pipe, or aftermarket?
Old Oct 11, 2021 | 11:49 AM
laurel51's Avatar
laurel51
I did get an aftermarket one from rock auto, the replacement should be here tomorrow. Except for the flaw, the new one looked identical in every detail to the old one, could have come out of the same mold! But - - - - -
Old Oct 12, 2021 | 07:28 AM
Yep, some of the aftermarket have some issues in production. Also you will have to grease the o ring on the aftermarkets as they run a hair larger then stock and have a tighter fit.
Here is the DIY and trick below.
https://www.northamericanmotoring.co...8-no-heat.html
Cngizbleevng
Apr 26, 2020 03:29 PM
Kelloinc
R55 :: Clubman Talk (2008+)
Aug 10, 2019 11:56 AM
cheetoman
Jun 7, 2019 08:55 AM
jjcsnlynn
Feb 16, 2019 08:12 PM
