Other Service w/ Valve Cover Off
Old Oct 6, 2021 | 05:17 PM
dayman's Avatar
dayman
Replaced my valve cover gasket about a year ago, but it's started leaking again (probably because I didn't follow the proper bolt tightening procedure...). I'm planning on doing it over again and was wondering what other items could be serviced as well while I have all those parts off the engine.
Old Oct 7, 2021 | 11:11 AM
COSilverMini's Avatar
COSilverMini
Maybe the oil filter housing seal if its leaking, though most of that is from underneath. Inspect all the vacuum lines while you have it all open. Inspect the thermostat housing seal, plugs wires if need be and coil. All I can think of.
Jwanck11
17
Nov 13, 2019 07:05 AM
olson187
Oct 21, 2015 05:25 AM
pepperstripes
Apr 7, 2015 01:22 PM
R56BrgMcs
May 3, 2013 10:07 PM
