R56 a softer clutch
Old Oct 6, 2021 | 10:32 AM
genik's Avatar
genik
a softer clutch
Since day one of purchase of the beloved R56S the stiffness and hardness to press the clutch pedal was always strange. After the passing of the years, its beginning to become a thing to take in mind of and wish that it could be softer. So i had to ask here if anyone has ever though of this, and if there is a way to make it softer.
Old Oct 6, 2021 | 11:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I recently added a Clutchmasters FX100 kit to my Clubman, and the pedal stiffness is slightly less than stock. Might look into one of their kits. I installed the kit with the steel flywheel, which is about the same weight as stock, but single mass.
Old Oct 6, 2021 | 11:43 AM
Mark_SF's Avatar
Mark_SF
Is it hydraulic or cable?
Old Oct 6, 2021 | 11:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Are you new to Minis? All Minis have a hydraulic activated clutch.
Old Oct 6, 2021 | 12:01 PM
johne123's Avatar
johne123
What you're talking about is the springs in the pressure plate. As a clutch wears, the engagement point in pedal travel moves close and closer to the floor. Pedal effort also increases. You may not notice this change over time because it is so slight, but it will be very noticeable when you install a new clutch disc, pressure plate, and in the case of the R56, a new flywheel (dual or single mass). The clutch pedal effort is much higher on my VW Corrado with a relatively new OE clutch and pressure plate.
Old Oct 6, 2021 | 12:26 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
This also does not apply to the R56. Mini uses a "self-adjusting" clutch to prevent that change in pedal stroke. The slave cylinder is internally sprung, so it is always engaged with the release lever. This also causes the throw-out bearing to always be engaged with the pressure plate springs. And, the pressure plate has a self adjusting ratchet, so the clearance is consistent. The only way pedal travel will change is if something bends or breaks in the system, which is not unheard of.
Old Oct 6, 2021 | 12:28 PM
genik's Avatar
genik
My friends 2005 VW Golf has a much softer clutch, also many other cars are the same... something must be done to soften the clutch, maybe replace those springs... no?
Old Oct 6, 2021 | 12:33 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Its not as easy as just replacing the pressure plate springs, and you can't just swap out the pressure plate from another car. Many factors go into defining clutch pedal stiffness - pressure plate springs are just one of those factors.
Old Oct 6, 2021 | 12:50 PM
genik's Avatar
genik
Its strange that after so many years, this clutch pedal stiffness issue hasn't been brought up and resolved by anyone, either mini drives/users or perhaps a 3rd party tech company.
Hmm could this be a "Marketing gap"?
Old Oct 6, 2021 | 01:27 PM
The older original clutches are harder
https://www.northamericanmotoring.co...utch-feel.html
Old Oct 6, 2021 | 02:16 PM
genik's Avatar
genik
What do u mean by "older original clutches"? The first clutch that came with the mini?
Old Oct 6, 2021 | 05:15 PM
3lusive's Avatar
3lusive
Older as in 2008 model year vs the LCI 2011+. I think I had a similar experience with my previous 08 clutch vs the 13 JCW, the 13 is definitely softer and easier on the leg.
Old Oct 6, 2021 | 05:35 PM
genik's Avatar
genik
can the JCW clutch fit on the R56S?
Old Oct 7, 2021 | 07:07 AM
They merged the parts. Yes. The older clutches produced before that date had a harder clutch plate.
Old Oct 7, 2021 | 04:52 PM
genik's Avatar
genik
Is there a way to find out if the clutch/disk installed is the original one or not?
Old Oct 12, 2021 | 07:45 AM
Should be Valeo on the friction disc and it will have the genuine MINI marking. On that part it will have the original part number or the last 7 of it.
Old Oct 12, 2021 | 08:14 AM
genik's Avatar
genik
will i need to remove it to find out, or might there be some way easier to check if its the original?
Old Oct 12, 2021 | 08:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
You could crawl under the car and try to determine if the bellhousing bolts have ever been removed. If they haven't, I would suspect original clutch.
Old Oct 12, 2021 | 04:55 PM
johne123's Avatar
johne123
I guess I forgot about that. I have an ‘07 with ~70k miles on it’s original clutch. Mine has what I would consider a relatively light clutch pedal. When our WRX’s clutch was getting thin, driving that car with a stress fracture in my left foot was not fun.
Old Nov 11, 2022 | 11:34 AM
genik's Avatar
genik
Could i have a pic of the area where those bellhousing bolts would be, cause i dont understand where exactly i should be looking to.
Since the clutch has been replaced with an original part by a technician, is it needed to d
etermine if the bellhousing bolts have ever been removed or not?
iDriveR56
May 4, 2021 07:15 PM
Kennedy
12
Apr 3, 2008 09:31 AM
MiniJayhawk
Nov 1, 2007 11:57 AM
bambam
Aug 23, 2007 08:44 PM
birdmanf16
Mar 16, 2007 09:04 PM
