R50, R53 Body Control Module, BC1
Audio Video/Electronics
  • Audio Video/Electronics - R50, R53 Body Control Module, BC1 - Used - 2002 to 2006 Mini Cooper - Cockeysville, MD 21030, United States
    $60
  • Location Cockeysville, MD, 21030, USA
  • Compatibility
Make Model Year
Mini Cooper 2002 - 2006
R50, R53 Body Control Module, BC1 pulled from a 2006 MINI R50. I bought this thinking mine had gone bad, but my problem turned out to be something else (you can read my thread here.).
I know it definitely will require coding for remote keys to work. You might be able to use it otherwise without coding if your MINI is similar enough. This came from VIN WMWRC33556TK18298, so you can decode the VIN to see all the details.
If you need it coded. Way Motor Works should be able to handle it for you.
The donor car had no signs or water or corrosion in that area. It was a MINI with a CVT, so I suspect that's why it ended up at the salvage yard.
The cover and and mounting nuts are included.
Asking $60 shipped Conus.
