Reset adaptations
Old Sep 1, 2021 | 03:14 PM
kandpand's Avatar
kandpand
Reset adaptations
I have a 2003 R50 that has the P2097 code. I have read several posts that talk about resetting the adaptations of the DME. What can I buy that allows the reset?
Old Sep 2, 2021 | 04:24 AM
ChiefM's Avatar
ChiefM
You can reset the ECU from the speedo.
1. With the key in the ignition, but in the off position, press and hold down the odometer reset button with one hand, while holding the button down, switch the key in the ignition to position 1 (first click) with the other hand.
2. The screen will have a number and the word “tESt”.
3. Scroll through the numbers by pressing the odometer rest button, through to 19 and wait a moment. (Note: the number order is: 1,2,10,19)
4. The message will say 19 "L i-off", flash to "L i-on", and back to "L i-off" again. When "log i-off" appears, press the odometer rest button again. You are now in the system.
5. Scroll through to 21. tESt and wait a moment. 21.0 rESEt will come up. Press the button once.
6. Your gauges will now make some sounds and movements. Once the lights come back on start your car. You have now reset your ECU and your MINI is now ready to relearn the new mods and your driving style
rob.james.arias@gmail.com
Jan 8, 2016 09:27 AM
Prima
St. Louis MINI Club
Sep 18, 2006 12:07 PM
Bikeguy57
Dec 20, 2005 05:20 PM
