2011 MCS - 90 degrees outside and snowflake warning
Old Aug 22, 2021 | 03:12 PM
Dcb22's Avatar
Dcb22
My wife went to fill up the car with gas. When she left the gas station, the CEL came on and also the snowflake warning (for possible ice).
Thing is, it's 90 degrees outside here in North Carolina. The external temperature reading says it -40 degrees.
CEL is P0073
Any ideas?
Old Aug 22, 2021 | 03:25 PM
renchjeep's Avatar
renchjeep
I am gonna say your ambient air temp sensor has failed, or the wiring has been damaged. -40 is the "default" number, IIRC.
Old Aug 22, 2021 | 03:46 PM
Dcb22's Avatar
Dcb22
If it's just the ambient air temp sensor, why would that trip the CEL?
Old Aug 23, 2021 | 06:19 AM
renchjeep's Avatar
renchjeep
The ECM uses that information for calculating things like fuel mixture, I would imagine. I know that when my wife's 2013 Justa Convertible had that code, it was because some critter chewed the wires leading to that sensor, and the MIL came on with a P0073 code.
Old Aug 23, 2021 | 06:28 AM
Dcb22's Avatar
Dcb22
Thank you. I need to find a thread on how to replace the ambient temp sensor...
Old Aug 23, 2021 | 12:03 PM
renchjeep's Avatar
renchjeep
On my 2011 MCS and my wife's 2013 Justa, it is kinda under the front bumper, actually comes a little bit through a hole in the bottom of the bumper cover. On the right (passenger) side, IIRC. I was able to reach it by jacking up the car and reaching into the underside of the bumper cover.
Old Aug 23, 2021 | 12:20 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
^This. If you lie on the ground, the temp sensor is on the underside of the bumper, almost directly under the fog light. Removing the fog light access panel in the wheel well, you can gain access to the sensor and harness through the access hole.
MINIMAN1411
Aug 14, 2015 08:00 AM
the matey
Feb 29, 2012 05:10 PM
3pedalMINI
May 2, 2011 09:09 PM
tccox
Mar 12, 2011 06:54 AM
dabus3719
Jan 13, 2011 12:46 PM
