R56 recaro installed, SEAT POSITION SENSOR code(0093BF) ON!
Old May 12, 2015 | 02:03 AM
mini_aaron's Avatar
mini_aaron
Haaaaaaaaahhh.
I just installed a recaro sp-gt2 seat for my mini.
After messing with the inclosed recaro resistor(measured 2.1 ohm), I was able to erase "SIDE AIRBAG CODE(0093AC)" with 3.3 ohm resistor, not the recaro one.
[attach][/attach]
But there was another code (oh I used ISTA bmw device to detect/test/erase fault memory), which was... "SEAT POSITION SENSOR(0093BF)"
Since that sensor is a part of Airbag system, the airbag light is still on.
(sensor helps the system to decide how hard the system explode the airbag according to seat position on the seat rail),,
So, I am trying to deal with the sensor now,
[attach][/attach]
(The SEAT POSITION SENSOR/magnet parts)
[attach][/attach]
(Magnet part on my oem seat)
[attach][/attach]
(Sensor taken off from the oem rail)
1. Anyone had this issue with seat removal/aftermarket seat install?
2. How should I figure this issue? Any recommendations?
I prefer to transplant the sensor to my recaro setup to have steering air bag performing properly when needed.. but I will need to cut the wires to remove the connector from the seat. (seat heater/Pressure sensor wires are coming from inside of the seat and comes in to the connector)
Help~!!
[attach][/attach]
Picture above shows two wires on the right(comes from the seat position sensor, goes to the car).. the multiple wires on the left is from inside of the seat itself, I am assuming they are for heater/pressure.
[attach][/attach]
And the picture above is basically the same connector(yellow casing is off now).
Old May 12, 2015 | 02:58 AM
mini_aaron's Avatar
mini_aaron
Just quickly tried to measure the ohm from the two pins(brown wire and ivory wire) coming from the sensor,, no respond... :( Don't understand why the green one joins there..
Old May 12, 2015 | 01:29 PM
shörtlegs's Avatar
shörtlegs
But those seats are sick!
Old May 13, 2015 | 06:36 PM
mini_aaron's Avatar
mini_aaron
So I was able to detach the "seat position sensor" and the wiring, the connector from the original seat(not the metal plate on the rail yet..tho),
going to try connect the sensor to the car and will see...
Funny thing is,, no minis here in Korea have that seat position sensor on the seat thus no air bag light because of that sensor...
It looks like only US/CANADIAN version minis are equipped with that feature(advanced airbag system).
Old May 14, 2015 | 08:54 AM
richardsperry's Avatar
richardsperry
Because Race Car... Put Electrical tape over the light... Otherwise, try very hard not to get into an accident, with no side/seat airbags, you're gonna die...
Old May 14, 2015 | 09:20 AM
" It looks like only US/CANADIAN version minis are equipped with that feature(advanced airbag system). "
Yep it an Airbag US thing and i think a couple other countries.
Old Aug 4, 2021 | 10:01 AM
bugeye1031's Avatar
bugeye1031
Moderator
Were you ever able to resolve this issue? I have the same problem....but with some F56 seats instead of the Recaro's.
Old Aug 4, 2021 | 01:26 PM
Jason Cornelius's Avatar
Jason Cornelius
When I did my driver seat, I actually moved that sensor over, and have a 2.2 ohm resistor in for the airbag, and de-pinned the seat heater. When I moved the seat I did have the battery hooked up and got the airbag light, which was cleared, via schwaben, and hasn’t been back. When I switch back I’m going to unhook the battery and see if I get a light.
mini_aaron
Aug 4, 2021 06:55 PM
StuRat
Aug 8, 2018 06:06 AM
fjork_duf
R58 :: Coupé Talk (2012+)
23
Oct 10, 2014 11:08 AM
golgo13
Nov 8, 2013 12:51 PM
HC0624
May 13, 2006 03:08 PM
