Speedometer dying when im driving!!
Old Jul 29, 2021 | 02:07 PM
dirtybubbles's Avatar
dirtybubbles
As the title says, my speedometer is acting crazy. It goes off and on when im driving, same with the temp gauge, it goes up and down. Also, my tachometer is acting crazy too. It’ll turn off on it’s own when im driving. My obd too wont communicate with the ecu(idk if it is because it’s a cheap one)
i already checked alternator and the 42 pin for corrosion so any help is appreciated as this is my first car
videos are in this link
https://imgur.com/a/ZZBWjl5
File Type: mov
Old Jul 30, 2021 | 08:26 AM
mrbean's Avatar
mrbean
This type of behavior can sometimes be attributed to signal interference on the CAN bus. This might also be causing the issues with you scanner.
The best way to check this is with an oscilloscope.
Old Jul 31, 2021 | 08:24 AM
kaneguy's Avatar
kaneguy
Does it behave the same when you are just idling and not moving. If it stops then it would suggest a loose cable or connector.
Here2Go
Electrical
Jul 20, 2021 04:56 PM
Blayne
Mar 30, 2013 02:40 PM
ieandro
Sep 25, 2011 09:25 AM
jman1
Jan 29, 2006 12:57 PM
