JCW GarageInterested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Thanks for prompting me to order that. Did the screws come with it? Not 100% sure but I think the foam seal has some part in marring the gel badge. Mine is a little disintegrated in that area. Both will probably go NLA like everything else. $30 https://new.minimania.com/part/NMX76...r-Hood-R52-R53
They make a killing on various bolts 'n fasteners like astronomical YOWZA! in some cases like with the valve cover bolts which are a ridiculous price but I bit the bullet when I first got my car because those bolts were slightly rusty...
...have since accumulated many spares from junkyard cars that still had good ones.
Stainless steel alternates a good option these days though,
might get a set at some point.
Similarly,
I was astounded with shock when I saw the condition of the bolt for my pass. side motor mount when I changed it out,
not too bad at $11, but still an eleven dollar bolt is a bit pricey!
I agree that the foam seal is the culprit for marring, in conjunction with bonnet alignment too I reckon,
dealer has it slightly cheaper...
...but again,
$30 for a stupid foam strip!
May try and investigate different varieties of foam to find a possible high quality alternate instead of buying the OE part and just use 3M VHB tape to affix it.
Nice find and great info on this page! The works sticker was faded on my GP, and a bit of 40% acetone took off the black marring and made look almost brand new... there's still a bit of yellowing though!
Yes, they slide off with a bit of persuasion and then reuse them for the stainless bolts. The only thing which you will be missing are the longer bolts which also acts as a guide for 2 cables.
Stainless bolts M6 x 35mm
I bought these stainless bolts
URL: https://rb.gy/dhu3am (dutch site, so use google translate)
Specs
DIN 912
M6 x L 35mm
5mm hex bolt
Quality : RVS / INOX A4
Stainless washers M8
And these stainless washers
URL: https://rb.gy/powryc (dutch site, so use google translate)
I am a little worried about stainless into the alloy of the head.
I'm not sure what sort of persuasion you used to get the collars/bushings off the screw for re-use, but I assume it was something like the way I did it. I used a large pair of Vice-grips to squeeze across the collar and screw tip to force the collar off. Then I used an 11mm socket and a hammer to drive the collar onto a replacement screw.
I'm wondering if the JCW sticker itself is sold anywhere... I found the JCW airbox logo as a separate part, but not this... Was considering buying a used S intercooler cover, and painting it body color and slapping a sticker on, instead of ruining my current JCW cover.
