Hot unless AC is cranked
Old Jun 24, 2021 | 04:05 PM
CooperCrazy333's Avatar
CooperCrazy333
Anyone run across this issue? Got a Bluetooth obd reader. Car runs hot like 210 hot unless AC fan is all the way full. Once full fan is on, Car runs at 180, the second you bring it off full it goes back to 210, but if you switch it back to full it cools down. Haven’t tried max ac this is just with normal ac
Old Jun 24, 2021 | 04:45 PM
Jason Cornelius's Avatar
Jason Cornelius
Depending on year and model you are fine. Mine runs around 220 when cruising and when the ac is on full blast it will run down in the 170’s.
Old Jun 24, 2021 | 06:47 PM
CooperCrazy333
No kidding, I guess it’s not throwing a warning. Thanks for the info
Old Jun 24, 2021 | 06:51 PM
Jason Cornelius
Seriously, I have bleed and replaced a lot of cooling parts since April and even before then my temps have always been there. On hot humid days it will hit 225-230 just sitting there if I don’t have ac on full blast.
Old Jun 25, 2021 | 09:30 AM
Gubi's Avatar
Gubi
Modern cars are typically designed to run hotter, it helps with efficiency. Unless it's throwing a warning it should be fine.
I believe if you turn on sport mode it'll drop the temps as well, but I've never verified this.
Old Jun 25, 2021 | 08:54 PM
renchjeep's Avatar
renchjeep
My 2011 MCS runs at 226 or so unless I have Sport mode AND Max A/C on, then it settles at around 180.
cboy808
Jan 18, 2021 05:40 PM
MikewithaMini
Aug 16, 2012 04:49 PM
meb
Aug 23, 2005 08:47 PM
