base 04 overheating
Old Jun 15, 2021 | 05:08 PM
04redmini's Avatar
04redmini
base 04 overheating
My 04 base mini is constantly overheating. This morning I had codes P0128 and P0117. I swapped out the Thermostat, and Coolant Temp sensor and the car continues to overheat with them minutes of starting it. When I bought car I replaced I replaced the PS cooling fan? Amateur YouTube mechanic, what else could be causing the over heating?
Old Jun 17, 2021 | 07:22 AM
mrbean's Avatar
mrbean
If it's overheating just a few minutes after starting it makes me think the head gasket is blown.
Old Jun 17, 2021 | 07:45 AM
cooper48's Avatar
cooper48
You should also check the flow of coolant in the radiator. It's possible that the radiator itself is clogged. Might try a coolant flush product from AutoZone, O'Reilly's, etc. It's also easy to install the thermostat backwards (spring side goes inside the block - see illustration below). If that's the case it will not open/close properly.
Robert Marquez
Mar 12, 2020 10:43 AM
mountainhorse
Mar 1, 2020 02:56 PM
Cenla Mini
Jul 5, 2019 06:01 PM
Superdave88
Jun 10, 2015 09:34 AM
qaz5eng
Aug 7, 2003 09:19 PM
