R50/53 AC compressor shaft seal blew need oil amount recommendstion
Old Jun 5, 2021 | 10:11 AM
frankiev's Avatar
frankiev
I was replacing the AC compressor coil and stupidly removed the shaft seal snap ring . The seal shot out and emptied all the freon and some oil . I put it back together and bought a vacuum pump to evacuate the system .
Any idea how much oil I should put in ? Do I need to put it in the compressor or can I draw it in after evacuate.
Old Jun 5, 2021 | 06:12 PM
jjcsnlynn's Avatar
jjcsnlynn
It calls for 140 ml, which is around 7 ounces. That is for a completely empty system. If you didn’t loose that much, you can just 3-4 ounces and then vacuum it.
sampleman
Jun 3, 2018 08:17 PM
MCSmoonshine
Mar 21, 2018 05:04 PM
JAB 67
Apr 6, 2017 05:23 AM
Webhead68
11
Sep 22, 2012 04:55 PM
cpeters
Jun 10, 2010 05:27 AM
