2004 R53 Running on 3 Cyllinders / Injector Circuit Issue
Old May 5, 2021 | 01:39 AM
simenstava's Avatar
simenstava
I have an 2004 Mini cooper r53 that has a problem with running on 3 cyllinders. normaly i can turn the car off and on and it will run fine again, but if i give over 60-70% throtle it wil like cut out spark or fuel. and if i hold it for 2-4 seconds it wil stop running on cyllinder 3. If i start the car up again it will run fine.
When the car is COLD it runs totaly fine.
Sometimes the car would not start at all. but when it runs it runs great. except when i give 60-70% gas.
The Injectors are fine.
I have also checked the cables to ecu from injector, aslo fine.
1. Replaced MAP Sensor
2. Replaced Spark Plugs
3. Compression Check. All cylinders were between healthy
4. Replaced Coil
5. Checked, Wires from injector to ecu is fine.
Error code when running only running on 3 cyllinders
Have tried to fix the issue for a long time. i apreciate any help og tips i can get <3
WhyItKeepBreakn
Mar 23, 2020 09:16 AM
WhyItKeepBreakn
Mar 5, 2020 05:48 AM
j911brick
Feb 6, 2020 07:20 AM
duknbubs
Aug 20, 2018 05:58 PM
58minor
Jan 3, 2013 06:29 AM
