Suspension Clubman Lift Build - R60 shock absorber and coil spring
Old Apr 28, 2021 | 02:03 AM
mathewkhng's Avatar
mathewkhng
Hi! I'm planning to build a 3 inch lift clubman and now I'm looking for some doable solutions.
Wondering if It's possible to install the stock shock absorbers and coil springs from R60 countryman. They seem to have the same mounting points as R55s but few inches longer. The reason why I came up this idea is that it potentially gives more shock travel than typical shock mount spacer lift kit.
Camber might be an issue after lift but I believe camber plates can compensate.
Do you guys have experience about it and any thoughts and suggestions are appreciated. Thank you!
Dwayne C
Oct 14, 2019 08:10 AM
H2o racer
Jul 8, 2019 04:45 PM
scf
Aug 3, 2017 06:06 AM
Suspension Products
Jun 24, 2015 11:09 AM
Jun 24, 2015 11:08 AM
